Lower Pulley Install Question
Old Apr 20, 2003 | 05:48 AM
MORTIS's Avatar
Just installed a cageless 4lb lower pulley, struggled with the 67" belt for a while till I broke that casting piece of the tensioner. I now notice that with the A/C on and the truck at idle, theyre appears to be more "noise or a low murmur" when your inside the truck, and that it disappears once you accelerate. Ive checked the pulley and it appears to spin straight and not wobble. Could I have damaged one of the idler pulleys in the middle by torqueing them down too tight? Or is this due to the fact that its a cageless and there's nothing to dampen the sound of the supercharger and pulleys? I know that there's suppose to be more noise when you get on it, but is this murmur at idle normal also? Thanks in advance.
Old Apr 20, 2003 | 07:21 AM
Rob_02Lightning's Avatar
Mine sounds like a Desiel on Idle
For some it's the marble in the Can sound
I think they call it cavatating ???
If you touch the gas a little and bring up the RPM's,
it goes away RIGHT ?
It's normal for most with aftermarket pulleys
Nothing to worry about
ENJOY THE NEW POWER
Old Apr 20, 2003 | 11:09 AM
Fast Gator's Avatar
Thats why the factory lower pulley has that large rubber damper on it.
If it bothers you and your running a chip, you can have the idle moved up
Old Apr 20, 2003 | 04:22 PM
MORTIS's Avatar
Thanks for the info guys, thats what I was hoping was happening. Have a great Easter
Old Apr 20, 2003 | 04:25 PM
dirtchicken's Avatar
Mortis, did you make it to the canned food drive yesterday at the old costco in Salt lake?? I was gonna go but I had to work.
Old Apr 21, 2003 | 01:05 AM
MORTIS's Avatar
Dirtchicken,
No, I didnt get to either, I had an errand to run at 9:00, and I didnt read the email from DJY, till last nite. Kinda wished we could've gone though, just to see a "Hawaii Lightning" family reunion
