Intercooler fluid
Old Apr 14, 2003 | 10:41 PM
1badlightning's Avatar
Intercooler fluid
Is the intercooler fluid just regular antifreeze coolant mixed with water like the radiator fluid ? (half coolant half water?)
Thanks for any info!
Old Apr 14, 2003 | 10:51 PM
EZGZ's Avatar
yep
Old Apr 14, 2003 | 11:16 PM
ST.ELMO'SFIRE's Avatar
i am oing to run water wetter from redline during the summer
when i ran it in my mustang (can't have antifreeze in a bracket car as you know) it ran a little cooler. every little bit helps
Old Apr 15, 2003 | 12:17 AM
Lightning Struck93's Avatar
Only reason to run anti-freeze in the summer is corrosion resistance, and there's better things for that. Otherwise straight water+water wetter+a corrosion inhibitor is always best..
Old Apr 15, 2003 | 09:14 AM
Fast Gator's Avatar
I run 2 bottles of Water-Wetter in my intercooler along with the JDM heat exchanger. Every little bit helps
Old Apr 15, 2003 | 09:34 AM
Silver_2000's Avatar
The Coolant raises the boiling point AND lowers the freezing point. So to say the only reason to run antifreeze in the summer is to prevent corrosion is misleading, if not down right wrong.
It also keeps the parts lubed, keeps deposits from forming that can clog the system, prevents foaming, etc etc
Doug
