How do i tell?
Old Apr 8, 2003 | 09:14 PM
slowsupraTT's Avatar
How do i tell?
I think my truck might have been fixed up more prior to me getting it. Right now it supposed to just have 4.10 gears, k&n intake, jdm superchip, and borla exhaust. I just found out it has a boost bypass after a little investigation becauase i was gonna do it after i got a 4lb pulley installed? If there a way to tell if it use to have a pulley? I was about to pull a plug to see if they where the it22's but i couldnt find my sparkplug socket. Also can someone get me the part number for the MAF to see if got the normal 80mm or if it has been changed to a 90mm( it's a 2000). Thanks for you help.
Old Apr 8, 2003 | 09:18 PM
lightninkid's Avatar
i would imagine that if it had the k&n intake that it would have a 90mm maf on it but dont hold me to it.
Old Apr 8, 2003 | 09:20 PM
did they not make a k&n for the 80mm?
Old Apr 8, 2003 | 09:26 PM
Well now i just opened the airbox and to my suprise it has the stock airfilter but with the cut-outs on the bottom. Also all of my pulleys except the top one has numbers on it and says ford on them....
Old Apr 8, 2003 | 10:18 PM
Silver_2000's Avatar
There are LOTS Of pictures on the various sites that will help you determine if your pulleys are stock or not. The MAF is a bit tougher BUT if you have a stock airbox it is UNLIKELY you have a 90mm maf on a 2000.
Doug
Old Apr 9, 2003 | 01:48 AM
Do you know any sites off at hand? Thanks
Old Apr 9, 2003 | 02:13 AM
cyntaxx's Avatar
Your K&N is a panel filter that resides in the stock airbox correct? Not an open-element cone-shaped one? If so then chances are you still have the stock 80mm MAF.
Old Apr 9, 2003 | 02:18 AM
cpeapea's Avatar
i think an it-22 would be too cold of a plug for stock, it wouldnt idle right very long
Old Apr 9, 2003 | 06:27 AM
Rob_02Lightning's Avatar
You may never know what it USE TO HAVE.
Mod it
Race it
AND ENJOY
Old Apr 9, 2003 | 06:35 AM
YAEGER's Avatar
hey i have a 8omm race maf from granatelli if your intrested in buying it its bigger than a 80mm stock i'll sell you it cheap it just sitting in my basement in a box i had it on my 99 L
Old Apr 9, 2003 | 06:38 AM
YAEGER's Avatar
i also have the airriad box for the complete system
Old Apr 9, 2003 | 09:19 AM
This belongs ONLY in the classifieds...
Doug
Old Apr 9, 2003 | 09:20 AM
My website in my signature and the thousands of Photo Galleries here....
Here is image borrowed from Teamjdm.com that shows the stock lower pulley
Doug
