HELP! Important question!!
Old Apr 8, 2003 | 06:36 PM
Vinny's Avatar
somehow under the wheel well of the drivers side front a wire got unplugged. There is a bunch of wires wrapped in tape adn it splits 2 ways. One goes to the fog light. Where does the other one go? Can i run the truck with it unplugged. I would go play around with it but it is snowing/raining and i cant lay on teh ground. Any help is appreciated. the truck seems to run fine and all the lights seem to work. Any suggestions??
Vinny
Old Apr 8, 2003 | 06:48 PM
soap's Avatar
Why not just plug it back in.......
Edit........just noticed what you said..........
I would remove the wheel well and find out where it goes.
--Joe
Old Apr 8, 2003 | 06:50 PM
Flying Mofo's Avatar
Banned
yea, go plug it in. Im sure its needed.
Old Apr 8, 2003 | 06:53 PM
Vinny's Avatar
cant see where it goes and the ground is covered in snow adn rainin. NO garage. I guess i will fix it tomorrow. Just wanted to know if it was ok to run it.
Vinny
Old Apr 8, 2003 | 06:57 PM
JWLightning02's Avatar
If it cranks, drive it! Don't forget to make sure your lights work.
Old Apr 8, 2003 | 08:47 PM
LatemodelRacer2's Avatar
might be the other foglight wire.
Old Apr 8, 2003 | 09:32 PM
L in Detroit's Avatar
only wire right in the wheel well, i can think of is the abs sensors, if u look on the inside of the engine compartment, on the wheel well, u can see from there is a connector that clips to the plastic wheel well there, there is one on either side and the wire in the engine bay is wraped in wire wrap and in the outside is round and black..
jim
Old Apr 8, 2003 | 09:34 PM
sorry just reread and looked on mine, it goes nowhere, it just clips behind the bumper cover....
jim
Old Apr 8, 2003 | 10:16 PM
MISTERgadget's Avatar
I panicked when i noticed that on mine too.
On the pass. side it goes to the horn
It could be useful for adding an airhorn or some other doodad in the future.
Old Apr 8, 2003 | 10:46 PM
Vinny's Avatar
Ok so i should just clip it on somewhere out of the way. Thanks. I appreciate all the help especially all the ones that went out and looked. Thanks alot. I guess ill just pin it somewhere. Does it have an actual spot to hook onto or just stickit somewhere? Thanks.
Vinny
Old Apr 9, 2003 | 09:47 AM
mine is cliped directly above the hole it comes out, on the end is a clip that looks like the door panel clips that has little fingers on it, there is a hole about 4 inches above this goes into...
jim
