What temp does your e-fan turn on?
Old Apr 1, 2003 | 08:25 PM
415cid Goose's Avatar
Question What temp does your e-fan turn on?
Just wondering at what temp does everybody's e-fan turn at.
Old Apr 1, 2003 | 10:26 PM
Come on guy's, help me out.
Old Apr 1, 2003 | 10:31 PM
hslightnin's Avatar
not sure but my gues is 170 ish
Old Apr 1, 2003 | 10:33 PM
awhittle's Avatar
On low speed all the time. High speed any time that the air con compressor in on. I just run low speed durring the winter. It works great. I do not run any type of an electric thermostat. I run the stock water threomostat.
Hope this helps
AW
Old Apr 1, 2003 | 11:00 PM
L in Detroit's Avatar
i put a kit together with some hayden fans and wired it myself, but i purchased a sender from JDM separate, it turns on at 190 and off at 165 170...
jim
Old Apr 2, 2003 | 12:29 AM
air1kdf's Avatar
It should turn on around 10 degrees higher than the thermostat. Say you have the factory 180 degree thermostat, the fan should turn on at around 190 degrees.
Note that all thermostats are actually at least 7 degrees higher than advertised.
Old Apr 2, 2003 | 07:14 AM
loosebolt's Avatar
On at 180 and off at 170.....
Old Apr 2, 2003 | 08:30 AM
Fast Gator's Avatar
On at 188
off at 172
Old Apr 2, 2003 | 11:05 AM
Originally posted by Fast Gator
On at 188
off at 172
Who's kit are you using? What * stat do you have?
Old Apr 2, 2003 | 12:05 PM
Fast Gator's Avatar
JDM fan kit, thermostat was included in their kit
Old Apr 2, 2003 | 12:40 PM
cyntaxx's Avatar
are you guys using gauges to find your actual temps or just guessing based on the t-stats you have?
Old Apr 2, 2003 | 03:11 PM
autometer guage..
Old Apr 2, 2003 | 05:20 PM
Fast Gator's Avatar
scan tool
Old Apr 2, 2003 | 07:28 PM
cyntaxx's Avatar
according to my trip meter thingy it shows 79-80 deg. Celsius in 80 degree weather in the middle of traffic. Dunno how accurate that is though...
Old Apr 3, 2003 | 10:56 AM
HIHOAG's Avatar
On at 90c or 194F
Off at 80c or 176F
JDM kit.
