Rear end,speedo,and tire ????
Old Mar 23, 2003 | 04:54 PM
rodcobra's Avatar
I have a 99 i'm fixing it has a bent rear end i want to run 20' on it .When i fix the rear end can i put 4:10s in it and not have to do anything so far as the speedo goes ,it has 3:55s in it now Also is a F-150 rear end the same as a lightning ,so that i can use the houseing. I know we have bigger brakes and stuff .Any help or info will be nice Thanks guys Oh heres a pic of it ,i'm painting it the color of my cobra Thanks
Old Mar 23, 2003 | 05:02 PM
rodcobra's Avatar
http://www.nloc.net/forum/showthread...367#post312367 Heres some pics
Old Mar 23, 2003 | 10:00 PM
rodcobra's Avatar
come one guys i read these forums a lot and you know too much to not help
Old Mar 24, 2003 | 05:39 AM
cabraco's Avatar
here is a neat tire and wheel size calc that you can also plug in some different rear end gears, and it will show you changes in speedo and odometer. http://www.c5-corvette.com/tirecalc.htm
Old Mar 24, 2003 | 11:20 AM
MISTERgadget's Avatar
There's 2 different rear ends used in the f-150's. If you're going to use parts off of one, make sure you get the 9.75 rear axle, which is the same size as the lightnings. Your best bet would be to find a complete rear axle from a ford expedition, since they have the same brakes, etc..., and can be found with a limited slip and 3.73's
Old Mar 24, 2003 | 08:45 PM
rodcobra's Avatar
Old Mar 25, 2003 | 01:06 AM
rodcobra's Avatar
TTT
Old Mar 25, 2003 | 07:58 PM
rodcobra's Avatar
HELP
Old Mar 25, 2003 | 08:22 PM
You will have to reset the speedo for the 20's and 4:10's also. this can be done with a chip. Anything else you need to know?
Old Mar 27, 2003 | 02:06 AM
rodcobra's Avatar
What happens if you don't use a chip. i thought if you go to 20s and as long as you used a tire not too much taller it would not have a bad effect
Old Mar 29, 2003 | 12:37 PM
rodcobra's Avatar
TTT
