Need a 68" or 68.5" blower belt..
Don't know if this info will help you but when I but my 4 lb'er on I couldn't get the belt to go on by losing the tentioner alone. So removed both idle pulleys put the belt on and then put the idle pulleys back on. It wasn't hard at all to re-install the idle pully's afterwards.
Suavy
Suavy
Goodyear Gatorback 4080685 SC Belt
1999-current Ford Lightning
& 2002-current Harley-Davidson F-150
*** to be used with 2 lb. Upper & 6 lb.
Lower SC Pulleys ***
Price: $40.00 shipped!!
Here's 68-1/2 Jeff
I know the owner well
E-mail Terry, he'll mail it Monday and
you'll have it by Wednesday
Or try calling him right now, you'll probably catch him in
(772) 468-3585 Terry Reals
http://www.southfloridapulleyhq.com/...ucts_frame.htm
Click on Pulley
Then Gatorback
Here's 68-1/2 Jeff
Click on Pulley
Then Gatorback
sorry
didn't see your earlier post....just happend to have the belt sitting here on my desk.
Going by Napa'snumbering system, a 68 would be 080680, don't know if they have half sizes, but it would probably be 080685
Jeff what Pulley Combo are you running ???
I have 3 belts
My Stock One
(used that one for about a week)
A Goodyear Gatorback 4080660 SC Belt
2 lb. Upper & Stock Lower SC Pulleys
(used that one for maybe a month)
Goodyear Gatorback 4080675 SC Belt
2 lb. Upper & 4lb. Lower SC Pulleys ***
(I use this one for my 4lb Lower "or" along with
either my 2.93 or 2.80 Upper)
I have 3 belts
My Stock One
Rob I'm running the ASP 6 lber. My 67.5" belt was a little tight but was ok before I put the Metco idler setup on. With this setup the belt is tighter and at the limit on the tensioner...I could run the 67.5 but this belt is very very tight.
