One Last Question and Quick Help please
Old Mar 22, 2003 | 04:33 PM
L in Detroit's Avatar
on thew JMD headers the longer O2 cables go on the front O2's right, do i have to snap off the tabs on my O2's they do not line up with the connector tab holes....
tks
jim
Old Mar 22, 2003 | 09:51 PM
i assumed yes, and cut the tabs off the front O2 sensors so it will fit into the supplied longer harness, but for thoes who are about to undertake this project,
1: when doing the pass side go from the wheel well and undo the starter wires so they are loose, there are three wires that attach to the starter itself, undo these and pull wire out of the way, and the take off the bracket farther up the wire to keep it loose, also when reinstalling this bracket bend so it is out of the way of the new header.
2: u might have to cut the tabs off the stock front O2 sensors...
other than that went smooth except for the two missing clamps and the top collector bolts, these are a pain in the a?? to tighten up, lots of extensions and two swivels..
jim
