Serious Belt Squeaking Problem!
Old Mar 22, 2003 | 01:30 PM
cobra97snake's Avatar
Angry Serious Belt Squeaking Problem!
ok, i used to just have a little squeek at start up, then it would instantly go away....
then it got alittle worse, so instead of using WD-40 because of it's known problem of "drying" out the belt and making it worse, i went to the store and got that stuff called "Belt Dressing"
now this stuff claims to not dry it out, and to have less slippage.
so i put it on and it works, but the next day it's worse, so i spray some more...
now its to the point where it is way louder than the exhaust..... it screams, and is embarassing, then when i hit the gas to go, it even gets louder!!
what the heck can i do to stop the squeak? did i just not put the belt dressing in the right place? i just sprayed it on the belts.....
do i need a new belt?
Old Mar 22, 2003 | 01:59 PM
SLP 97 CAMARO SS GUY's Avatar
I dont have a Lightning, but I never had a time where that belt dressing stuff worked. I would just put a new belt/belts on and be done with it. How many belts does the L have? 1 or 2? Ive seen under the hood of an L before, just cant remember how many it had. That dressing stuff usually takes away the noise right then and there, but the noise usually returns within minutes or hours. It seems to me that when a belt gets glazed, thats it, its gonna squeak until you replace it.
Old Mar 22, 2003 | 04:12 PM
LIGHTNINROD's Avatar
I would never use a belt-dressing on the s'c'r belt. It has too much of a load on it. Just replace(NAPA) it and clean the pulleys off before you do.
Dan
Old Mar 22, 2003 | 06:51 PM
cpeapea's Avatar
yep, dont use belt dressing, just get a new gatorback
Old Mar 22, 2003 | 06:55 PM
Slick02's Avatar
put a little silicone grease on both sides of the belt and that will take care of your problem.
Old Mar 22, 2003 | 07:15 PM
Question
Slick02, what town in Morris County are you in? Im in East Hanover. Do you have an 02 Lightning? If so, what color? Mike
Old Mar 22, 2003 | 07:31 PM
tallimeca's Avatar
also
check the idlers. If your truck is stored for the winter..like mine, it could be the bearings on the idlers Mine are in a bad way. What happens is the idlers have a hard time keepng up with the rpm's of the engine and start causing friction on the belt, which causes it to heat and crack, and even slip.
Check your belt, and the idlers
Old Mar 22, 2003 | 10:07 PM
speeder's Avatar
Question Belt
Im having the same problem with the belt squealing, ive greased the idler pulleys and still have the noise, the next thing to try is a new belt.
Larry.
Old Mar 23, 2003 | 02:59 AM
Slick02's Avatar
SLP, i am in Hanover or Cedar Knolls, i have a black 02 harley but my next door neighbor has a red 01 lightning and another friend in town has a red 02 if that thats what your looking for
Old Mar 23, 2003 | 11:07 AM
No to be honest, I havent seen any Lightnings around here, but my friend Joe is from Florham Park and he says a guy who lives right down the street from him has a newer red Lightning, 01 or 02, hes not sure. Im just wondering if its the same guy you know? Do you know a guy named Joe? He has a newer green/gray 2-tone Dodge pick up with the V10 and he also has a blue/gray 89 GT Mustang that is loud and fast as hell. Mike
Old Mar 23, 2003 | 11:17 AM
Fast Gator's Avatar
You already have your answer, replace the belt. But anything with the word gator in it, has to be good
Old Mar 23, 2003 | 05:36 PM
Slick02's Avatar
i dont know anyone with a lightning in florham park, really there isnt many guys around this area with them, goes the same with the 02, 03 harleys. i rarely ever seen anybody with them if i dont already know them. but i have seen a blue/gray mustang that is loud flying around rt 10 or ridgedale ave before.
