Need help tapping autometer guages
Old Mar 20, 2003 | 09:58 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
info nugget...
another option.
Old Mar 20, 2003 | 10:14 PM
tallimeca's Avatar
bob
what happens when the stat isn't open????
Old Mar 20, 2003 | 10:39 PM
Suavy's Avatar
Soap do you have any pic. on where the boost gauge taps in at?
Help Suavy
Old Mar 20, 2003 | 11:02 PM
soap's Avatar
Help Suavy
You got email brutha......
--Joe
Old Mar 21, 2003 | 04:35 AM
Fast Gator's Avatar
soapster to the rescue
Old Mar 21, 2003 | 07:34 AM
Re: bob
The needle doesn't register until the stat opens.
Is it absolutely mission-critical to have a temp reading when the thermostat is closed?
Is that black duct tape on your setup?
Pic of boost gauge tap point.
Old Mar 21, 2003 | 08:48 AM
TINNMAN's Avatar
Where did you guys splice in this ignition wire?
Old Mar 21, 2003 | 08:58 AM
soap's Avatar
If I interpret this correctly you are trying to just get an on source when the ignition is in the on position. Those are all over. You can get it from the cig lighter, radio, the dash light cluster etc.
I did mine from the radio.
--Joe
Old Mar 21, 2003 | 09:22 AM
TINNMAN's Avatar
Yeah, my brother mentioned the radio. Thanx Soap, guess we'll go with that. By the way dude...do you ever sleep?
Old Mar 21, 2003 | 09:36 AM
soap's Avatar
FYI........you can buy the "Ford radio pullers" at any Pepboys, Autozone etc. They are only like a couple bucks.
I only sleep as much as I need to.........which ain't much...........ever hear of Mountain Dew
--Joe
Old Mar 21, 2003 | 09:43 AM
TINNMAN's Avatar
--Joe
Heh heh.....I gave up soda a long time ago, my dentist has a big enough boat I get my pep from Xenadrine now. That ephedrine stuff packs a real punch...
Old Mar 21, 2003 | 04:32 PM
TINNMAN's Avatar
Hey Soap...save me time from using a powerlight or V.meter if ya can, do you remember which radio wire you spliced into for power and which dimmer switch wire you spliced into for the lights? Thanx dude...if ya cant remember, Ill just bust out the meter once I pull the radio & switch.
Old Mar 21, 2003 | 05:47 PM
soap's Avatar
No friggin clue........I just used a test light to find out, and that's the one I tapped into.
--Joe
Old Mar 21, 2003 | 07:22 PM
tallimeca's Avatar
tape
yeah, that is black electrical tape wrapped around mine, like i said, i need to get a larger piece of loom instead.
The wire i used was either blue with a red stripe, or blue with a green stripe, i'll double check. Tap intothe lighter light for the lights on the guages.
Old May 14, 2003 | 09:24 PM
josho66's Avatar
Originally posted by 99svtlightning
There is a lot of info on this forum. I would search for each gauge install seperately...like boost gauge install, etc. They are all really easy to install. The simplest is the boost, you can tap in under your dash with a tee. You can tap into the headlight switch and into the fuse box for power. I would use one hook up for your power, ground, and headlight and fuse it. You can then splice into those wires for all your gauges.
Where do you tap into the headlight switch for power for the gauges???
