WooHoo Monster-Box
Old Mar 19, 2003 | 02:53 PM
Silver-Bolt's Avatar
WooHoo Monster-Box
My Monster-Box just arrived.
Old Mar 19, 2003 | 03:16 PM
ShaneMcKenna203's Avatar
Re: WooHoo Monster-Box
any chance they gave you 2 instead of 1? i'm looking into getting one myself. let me know what ya think after ya put it in. I've heard nothing but good things about them...
Old Mar 19, 2003 | 04:34 PM
bodawg's Avatar
What?! How long has this been in the works?
Old Mar 19, 2003 | 05:00 PM
NakMan's Avatar
Silver,
You gonna break it in on the dyno Saturday?
NakMan
Old Mar 19, 2003 | 05:23 PM
It won't be in for Saturday. I wish but no time to do it right now. Factory-Tech has been taking his time with this one. It was an unusual challenge. The core I sent him came out of a Lightning that was submerged under water.
Old Mar 19, 2003 | 05:57 PM
Ayrton's Avatar
The "submarine" transmission.
Old Mar 19, 2003 | 06:41 PM
SpankDog's Avatar
Banned
Hah, so whats the cost on one of these babys and what can they handle?
Old Mar 19, 2003 | 11:35 PM
It will handle more power than the Lightning community has seen so far. Contact Dr. Gregg Evans (aka Factory-Tech) for price and delivery information.
I have a few years experience in the automatic transmission parts industry. What Gregg is doing to these M/B's is unequaled by anyone. It's a complete engineered package front the front pump to the output shaft. This will be an investment into the future of my Lightning. Next up will be the rearend. After the drivetrain is up to snuff it will be time to build a beast of a motor. By the time the motor is in all systems will be in place to deal with the huge power. Brakes, trans, rearend, etc. I'll be ready.
Old Mar 20, 2003 | 12:05 AM
Ayrton's Avatar
Somebody asked over on the Harley site what Gregg did to the transmission, and this was his response.
Well, the monster box is a bigger badder tranny, I upgrade every clutch in the box, retune the shifts, and make it about indestructable. Her's a list of what i do...
Factory Tech Transmission Specialties
Build Date
Serial Number_____________________________
Build Sheet
Replace Low/Reverse friction plates
Replace Low/Reverse Pressure Plate
Upgrade Low/Reverse clutch stack-up to 6 plate element
Replace Forward Clutch steel and friction plates
Upgrade Forward Clutch friction plates with Raybestos Blue Racing Plates
Remove Forward Clutch Wavy Plate, upgrade to 5 plate element
Replace Forward Clutch seal rings
Replace Direct Clutch steel and friction plates
Upgrade Direct Clutch Drum, 7D044, with NEW 5 plate element drum and pressure plate
Upgrade Direct Clutch friction plates with Full Race friction Plates and Kolene steel plates
Upgrade Direct Clutch to 7 or 8 plate element
Replace Intermediate clutch steel and friction plates
Upgrade Intermediate friction plates with Raybestos Blue Racing Plates
Replace Intermediate Sprag Assembly
Replace Center Support Seal Rings
Replace Coast Clutch Drum
Upgrade Coast Clutch Drum to 6 plate Drum with ball bearing assembly
Replace Coast Clutch friction plates
Upgrade Coast Clutch to 6 plate element
Replace Overdrive Clutch friction plates
Replace Overdrive pressure plate
Upgrade Overdrive clutch to 4 friction elements
Clean and inspect Pump assembly
Replace pump boost vavle
Replace F81Z-7G422-AB accumulator valve body
Upgrade Accumulator Valve Body with Factory Tech Accumulator
Clean and inspect Main Control Valve Body
Clean and inspect EPC Solenoid Valve Body
Replace seals, gaskets bearings and misc. small parts as needed throughout.
Replace Pan Assembly
Upgrade Pan Assembly to deep plugged pan, Factory Part number F81Z-7A194-AB
Replace fluid filter
Provide (not install) External Fluid Filter Kit (XC3Z-7B155-AA) as specified for Transmission Rebuilds/Re-Installation in Ford Motor Company 4R100 Reference Manu
Transmission is Dyno tested before shipping
Hope this helps,
G
Old Mar 20, 2003 | 02:49 AM
ShadowLightning's Avatar
And to top it off the guy is a true professional. That list just gives a hint to how much work he puts into his stuff.
Old Mar 20, 2003 | 06:17 AM
Fast Gator's Avatar
I see myself becoming one of Greggs customers in the future
