Hesitation at WOT
Old Mar 17, 2003 | 03:38 PM
brap's Avatar
Hesitation at WOT
Just recently my truck started to 'hesitate' at WOT. I will floor it and it will rev-up then it will act like it is missing or something and wont really accelerate anymore. When I let off the gas, it will run real rough and barley idle for about 30 seconds ... then it corrects itself and everything is fine until i WOT it. The SES light never comes on.
Any ideas? I wanted to see if this is something I could fix before taking it back to the dealer again.
Bye the way ... this is with a chip, 5lb pulley, 90mm MAF. I took the chip out thinking that it might be the cause, but it still happens. I just replaced the plugs with BR7's last week ...
Old Mar 17, 2003 | 03:41 PM
SpankDog's Avatar
Banned
FUEL FILTER.
hopefully
Old Mar 17, 2003 | 03:44 PM
99svtlightning's Avatar
Either that or something is wrong with a plug...I would pull them out and check them again along with the filter.
Old Mar 17, 2003 | 03:46 PM
brap's Avatar
oh forgot to mention ... i also just changed the fuel filter and oil ... hoping that it was the fuel filter ... no luck.
I'll pull the plugs back out and take a look i guess ... I was thinking maybe a coil pack went bad? But wouldnt that throw a code?
Old Mar 17, 2003 | 04:17 PM
Griffin 01 L's Avatar
Are you hearing any pinging? While I was at REM weeks back there was a black 00 that had the same problem you discribed. After troubleshooting for a while it turned out to be a bad o2 sensor.
Hope this helps,
Griffin
Old Mar 17, 2003 | 05:39 PM
LIGHTNINROD's Avatar
My guesses:
1. Bad coil(s)
2. Dirty or clogged injectors
3. Low fuel pressure--bad pump, regulator, or restrictions in the lines
4. Fuel inj. or eng. control systems malfunction
Dan
