E-fan sensor and water temperature sensor
Old Mar 17, 2003 | 10:15 AM
Jaxtoy's Avatar
Question E-fan sensor and water temperature sensor
I just installed JDM e-fan.My question is where can i hook-up auto meter water temperature sensor since i had to remove it from the block for E-fan sensor.
Old Mar 17, 2003 | 12:46 PM
LIGHTNINROD's Avatar
I did a search--maybe this will help:
http://198.65.157.241/forums/showthr...+intake+sensor
Dan
Old Mar 17, 2003 | 04:38 PM
L in Detroit's Avatar
i went the way of installing the sensor to my auto meter ele guage in line with the heater core, i did this because i didnt like the idea of tapping the intake, and if i tapped the thermostat housing it will only read when the thermostat is open, so if u have a mechanical guage it easy, one "T" fitting with barbed fittings on either end to splice into the core hose and the open end goes the sensor, if u have a ele guage, same set up, but u have to run a wire from groung to the new brass fittings...
jim
