Need 14mm Allen ASAP????
Where in the hell can I get a 14mm allen socket? I bought a used set of pulley's and of course they failed to include the socket. I tried Sears, but as big as they go is 10mm. Any ideas? I could order one, but I was planning to install this evening. Thanks!
Dont need a 14mm socket to install the pulley. Get yourself two grade 8 bolts. big eough to where they will fit into the two small holes on the frnt of the stock pulley. Grind the bolts down to make two dowl pins. put both dowl pins in the two small holes in the stok pulley. Use a bar handle from a floor jack and put the bar between the two dowls. then pul to the right or if your were to tighten a bolt to take the pulley off. Id post pics but i dont know how to post them in the thread. This is how Ive done mine and many others. Hope it helps
Vatozone sells a 3 pack which includes a 14mm Hex...
Or do what i did...
Take a 14mm hex key. Where the straight part is, cut off 1/4" of it and shove it into a 14mm socket. I made mine half inch drive
Or do what i did...
Or do what i did...
Or do what i did...
