intercooler pump switch
Old Mar 11, 2003 | 11:41 PM
LatemodelRacer2's Avatar
I am going to put a toggle switch on my intercooler pump. Which wire on the pump do i tap into with the switch. I know im putting the switch to a ground. I want to tap into the wire at the pump not at the computer. there is a black and then a white wire going to the pump so i need to know which wire to tap into.
Old Mar 11, 2003 | 11:47 PM
Don's Bolt's Avatar
If I remember how I did it
I tapped power fron the distribution thingy on the passenger side, then to a inline fuse, then to a switch and finally tapped into the white wire.
I don't think I grounded it, since I was told it is allready a grounded circuit.
I am not positive about this as it was over a year ago when I did it.
http://www.nloc.net/forum/showthread...er+pump+switch
Old Mar 12, 2003 | 09:23 AM
ttt
Old Mar 12, 2003 | 07:12 PM
Which of the two wires going into the pump would it be Black or white.
Old Mar 12, 2003 | 07:48 PM
L8 APEX's Avatar
You want to switch the ground out of the PCM to the pump relay. That is easiest. Otherwide you will have to mount a relay and run a control ciruit to a switch and send the pump 12V positive on a 15 amp circuit or so. If you power it at the pump it has to be enough current to run the pump. If you catch it in the dist panel it is control current much less load.
Old Mar 12, 2003 | 09:23 PM
soap's Avatar
White wire.
--Joe
69stangscj's Avatar
Registered User
Re: intercooler pump switch
why would you want to do this????
Old Mar 12, 2003 | 09:24 PM
soap's Avatar
Originally posted by Don's Bolt
I tapped power fron the distribution thingy on the passenger side[/url]
Commonly referred to as the solenoid
--Joe
Old Mar 12, 2003 | 09:25 PM
soap's Avatar
Re: Re: intercooler pump switch
So you can run the IC pump while in the pits with the truck not running to cool down the IC.
Kinda the same purpose behind an electric water pump.......well other than parastic drag.
--Joe
Old Mar 12, 2003 | 09:28 PM
4D THNDR's Avatar
Before frying some relays, Read!
https://www.f150online.com/forums/sh...threadid=25117
Old Mar 12, 2003 | 10:10 PM
tallimeca's Avatar
wiring
i just ran a lead from the solenoid to a fuse, from the fuse to a switch, and from the switch i ran a wire right down to the motor and tapped into the power lead. Felt this was the best way. Any power surge will blow the fuse before frying anything. I used a regular ato setup. mounted the switch on the solenoid cover right below my fan switch.
Old Mar 13, 2003 | 12:05 AM
Can i just run a wire into the relay with a switch on the other end?
Old Mar 13, 2003 | 12:45 AM
does the white wire with orange line run to the fuse box? If so i could tap it there.
Old Mar 13, 2003 | 07:42 AM
69stangscj's Avatar
Registered User
Re: Re: Re: intercooler pump switch
--Joe
Ok, That makes sense to me now! Thanks Joe
Old Mar 13, 2003 | 12:41 PM
4D THNDR's Avatar
Unhappy Re: wiring
Originally posted by tallimeca
...Any power surge will blow the fuse before frying anything...
Damn, I wish you'd have said that before my relays fried and then the fuse blew, could saved me $230 dollars in repairs.
