Nitto extreme
Nitto extreme
I just put a set of Nitto tires (no drag radials) on my L. They seem to break loose really easy. Is that normal??? I have a 4 lb pulley/chip.FT acc./pinion snubber. Press. is about 28-30. The F1s didn't break loose this easily.
Hey Dr.D, I just put a set on mine and they are so easy to spin on the street that it makes me wonder if I did the right thing.
I am running a 6# lower and just installed an Accufab throttle body over the winter. I took it out last week and put about 3-4 miles on it, and everytime I hit second real hard it went sideways and smoked them for about 30 feet.
However, I was so impressed by a fellow Lightning owner on this boards 60 foot time against me last year running this tire, ( I was running 28 x 10 x 16 Hoosiers at 14 pounds at the time), that I went out and bought a set of Nittos. At the track they hook really well.
Besides I want to run the street class this year and need a DOT tire to do so at my track.
I have seen several 1.7's on the Nittos at the strip. I think you will be happy once you hit the track.
By the way, how's the pinion snubber holding up? I am still attempting to make them out of aluminum.
Marc
Marc
Marc
The snubber is still on and I have no reason to take it off. There are times ( like from a roll) when it can make the truck feel squirrelly but from a dead stop I like it. As a matter of fact, I don't even change settings. Roads are pretty good around here and the few places that are bad, duh-I just slow down a bit. Good product.
Back on topic, tho', these Nittos seem awful slippery on the street, and as I said, they are NOT DRs. Maybe they need more or less air. I'll find out.
But like SpankDog said, I do like the look compared to the F1s.
I am looking to get a set of drag radials and i was just woundering if anyone has any insight on the BF goodrich ones should i go w/ the g force t/a one or the comp t/a one or maybe the Nitto's instead??
Smok'n L
Smok'n L
bfg makes good dr, bfg is way better than nitto by far. nitto suck for performance says road test done about a year ago (I work for a tire company) bfg comp t/as outperformed nitto in every category. im not sure though if the same applys for dr's though
cpeapea, Thanks for the reply but one more for u would u go w/the gforce or the comp t/a's??? I dont plan on just using them at the track when i dont have my 20's on ill have them on for weekend driving also.
im guessing that both suck in the rain too
Smok'n L
Smok'n L
