Help Predict My ET!
Old Mar 2, 2003 | 04:09 PM
HANKFAN's Avatar
Question Help Predict My ET!
My local track is an 1/8 mile track and I haven't been able to run my truck at a 1/4 mile track yet. I haven't even run my nitrous at the 1/8 mile track yet. I was wondering what you guys think my L would run in the 1/4? Mods are in my sig and I will be running Nitto 555R's! From reading the board I am guessing I should be at least in the 11.80's. Any thoughts?
Old Mar 2, 2003 | 04:22 PM
soap's Avatar
Where are you running at?????
I would say 7.5's are in your reach.
--Joe
Old Mar 2, 2003 | 04:31 PM
HANKFAN's Avatar
My local track is Elk Creek in Virginia. The closest 1/4 mile track is Bristol. Any guess what I should run in the 1/4?
Old Mar 2, 2003 | 04:35 PM
LightningTuner's Avatar
I'd say 12.20s, and that's IF you can launch on the spray on the Nittos.
Old Mar 2, 2003 | 04:49 PM
soap's Avatar
Friendly debate here so...........
I gotta dissagree. I ran 12.2's with a lot less done than HANK.
He has gears/spray/all that suspension *****.
I will admit it is gonna be tough getting out of the hole.........better heat the hell out of those Nitto's
--Joe
Old Mar 2, 2003 | 04:52 PM
Rob_02Lightning's Avatar
I'm not sure "YET" Hank Fan, I'd say hi 11's too, if you can hook.
You know I want to know this answer too
BTW,
Sal, can you launch "and then hit the juice switch"
I'd think it would be a lot less stress on the DS and Rear, not to mention better traction, especially with those 28" Hoosiers you turned me on to
Old Mar 2, 2003 | 04:53 PM
LIGHTNINROD's Avatar
Just for 'giggles'----12.1-11.9s Go for it!
Dan
Old Mar 2, 2003 | 04:56 PM
HANKFAN's Avatar
Yeah I have to agree with soap. I know Beefcake ran 11.90's with a 6# lower and a 50hp shot. I am running a 4# lower and a 75hp shot so I should at least be in the high 11.90 range. Maybe in the high 11.80's if I can get the Nittos to hook. But I don't think that I will be able to launch on the spray with the 4.10's with the Nitto's even with the JLP traction bars. I probably will spray mid way through 1st gear to help reduce tire spin. I am shooting for 11.90's in the 1/4 and 7.50 in the 1/8th.
Old Mar 2, 2003 | 07:22 PM
svt360's Avatar
Hank i have the setup as you im hoping to be in the 11's also,but i have hoosier's
Old Mar 2, 2003 | 07:33 PM
Beefcakes truck was also an 01 vs your 00, which makes a big difference (the lower intake). He also had long tubes and was running a real 15" slick. His truck also ran 12.40s off spray.
I do have a little experiance tuning some 99-00s with spray . I really don't think you are going to hit 11s with what you have listed. But I sure do wish you luck, and hope you hit your goal .
Old Mar 2, 2003 | 08:13 PM
FuB's Avatar
FuB
Your ET will be.....
12.1213 exactly.:o
Old Mar 2, 2003 | 08:18 PM
ICULOKN's Avatar
Hank,
How far are you from Bristol? Where is Elk Creek? I dont know that track.... I am about 4 hours or so from Bristol, maybe one day we could meet up, I never knew you were in VA.... What part exactly?
Old Mar 3, 2003 | 12:04 AM
HANKFAN's Avatar
Sal- Thanks for the info. But I think you forgot....
I am JDM tuned! That should get me into the 11's by it's self right? J/K
ICULOKN- Elk Creek is in Wythville VA. I acutally live in Princeton WV (30 minutes away from Beckely WV). Elk creek is about 45 minutes away and Bristol is 2 hours away. I am for sure going to FFW in August at Bristol you should try to make it.
Old Mar 3, 2003 | 12:09 AM
I'm not touching THAT one with RTKILLA's hog.
Old Mar 3, 2003 | 12:50 AM
Certified Drunk's Avatar
14's, the tire's will go up in smoke!
