1994 Ford Lightning, cruise,horn,fog light problems
I have a 1994 Ford Lightning. The cruise control,horn and fog lights all went out at the same time. The fuses and relays are ok. what would be causing this? any one that could help in this matter would be appreciated. Thank You
Originally posted by paul12
Clock Spring Assy. 100.00 from ford. borrow a steering wheel puller from auto zone. 45 min job.
If yours has an airbag I would think twice before opening the steering wheel.
Broken clock springs are very common on all '94 models. The same thing happened to my '94. It does cost around $100 and is very easy to install yourself. Don't worry about the airbag, it's very easy to remove. Just remove the 4 screws on the rear corners of the center square part of the steering wheel (I think they are torx) and pull it out. Unplug the airbag connector and sit it aside. You will have to remove a couple of other parts in the wheel itself to get to the spring, but the wheel does not have to come off.
Good luck!
Good luck!
