exhaust leak? or normal?
Old Feb 27, 2003 | 06:33 PM
cyntaxx's Avatar
The spot between my midpipes and catback there seems to be some liquid (i think just water?) sputtering out on a cold startup. it's pretty noticeable and is more than a mist (leaves stuff on ground). It goes away after the truck warms up though...or at least the condensation leaves and I can't see anything leak through...maybe just air, gases, etc...
Is this an exhaust leak or just condensation that goes through on a cold start up due to contraction of the metals (due to coldness)
also if it is an exhaust leak, are there any ill effects?
Old Feb 27, 2003 | 07:19 PM
ARTIE54's Avatar
I, get the same thing on my 01, its condensation from the hot exhust and cold pipes. If you look when you first take off there is a bunch that comes out the exhust tips also! Artie
Old Feb 27, 2003 | 07:22 PM
zbornac's Avatar
not related to your question, but CHECK YOUR E-MAILS CYNTAXX!!!
-Kimball
Old Feb 27, 2003 | 07:24 PM
cyntaxx's Avatar
yep but isn't it a leak if it comes from where the midpipes and catback join? i would think that would be pretty tight but maybe not?
as long as there are no ill effects i'm not worried...just curious. i have some come out of my tips too...which i know is normal...
Old Feb 27, 2003 | 07:35 PM
ARTIE54's Avatar
The pipes expand when they fully heat up thats why the water seeps out when you first start up cold! Artie
Old Feb 27, 2003 | 07:54 PM
cyntaxx's Avatar
yep that's what i suspected (its in my original post)
thanks...
Old Feb 27, 2003 | 08:33 PM
LIGHTNINROD's Avatar
I've never noticed(?) condensation coming out up near the cats. Yes, I get it out the tips but if I saw it coming out near the cats, I'd take it to an exhaust shop and have it welded shut. You don't want carbon-monoxide finding its way into your cab...............dirt-nap time .
Dan
Old Feb 27, 2003 | 09:16 PM
yysenhimer's Avatar
Get under there and look for a carbon build up at all of the seams including the muffler seams. If you see a carbon build up, then you have an exhaust leak...
Old Feb 27, 2003 | 09:18 PM
cyntaxx's Avatar
hmm how at risk am i? I dont idle in closed garages (mine is open..more like a carport). would i be at risk driving it?
i know that sounds stupid since it can't kill you while driving with all the air but i figure maybe it would trap in the cab?
maybe this could be my excuse to get longtubes
Old Feb 27, 2003 | 09:19 PM
cyntaxx's Avatar
i will do that tomorrow.
how bad is an exhaust leak? something major or minor? any ill effects? (other than carbon monoxide seepage)
Old Feb 27, 2003 | 10:01 PM
yysenhimer's Avatar
I drove around for 8 months with multiple exhaust leaks from the stock exhaust. Granted, they weren't that bad, but they still annoyed the $h!t out of me. The stock exhaust was leaking and the mufflers were leaking at the seams. That's what I used as an excuse to get long tubes.
Old Feb 28, 2003 | 06:38 AM
loosebolt's Avatar
As someone mentioned earlier, it is a small leak until the pipes expand. A little exhaust leak is nothing to worry about.
You want to talk exhaust leaks, you should see some of the vehicles here in MI
Old Feb 28, 2003 | 11:53 AM
cyntaxx's Avatar
dont say that! i'm itching for longtubes! (kinda )
only thing that is stopping me is that for a couple of clams more i can do a monster box (whenever this stocker craps out on me..)
