Q for those that remove tailgate.
Old Feb 26, 2003 | 03:18 PM
TINNMAN's Avatar
What size torque bit is it that the bottom of the tailgate requires? The two torque nuts at the bottom, that bolt the tailgate to the truck, no the two that bolt the rubber covered braided wire, I have the right size bits for those. Thanx!
Old Feb 26, 2003 | 03:23 PM
clonetek's Avatar
hmm... i dunno.. i just unclip the wires & pull the tailgate off at the track.
Old Feb 26, 2003 | 03:28 PM
TINNMAN's Avatar
Uhh...wait a minute...ok..lemme RE-ask this question....ok..here goes..
Hey guys, got a q..how do I remove my tailgate? Do I need to remove the Torx nuts on the bottom of the tailgate as weel as the ones on the cable? Thanx..
Old Feb 26, 2003 | 03:30 PM
01Lightning's Avatar
You do not need to remove any bolts to remove the tailgate. The cables will unclip from the truck and the tailgate lifts off (be careful).
Hope this helps!
Old Feb 26, 2003 | 03:49 PM
SVT_KY's Avatar
Pull the little silver tabs out a tad, slide the rings off
the upper latch point, tilt the gate to about 45 degrees
and pull the right side off ... Simple once you do it, but
hard to figure out.
Old Feb 26, 2003 | 03:59 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Thumbs up
It is very easy to remove, no tools required.
This is why it has a keylock in the handle.
Old Feb 26, 2003 | 04:02 PM
Old Feb 26, 2003 | 04:09 PM
TINNMAN's Avatar
Done...like butter baby! Thanx guys...you saved me alot of time...& anger...which is what I would have been bubbling over with after I went & bought a torx bit to remove a tailgate that I can just unclip..
Old Feb 26, 2003 | 05:02 PM
SpankDog's Avatar
Banned
WooHoo dont drop it.!
Old Feb 27, 2003 | 05:26 PM
clonetek's Avatar
glad you got it!
