Need help to check plugs
Old Feb 26, 2003 | 11:36 AM
ub2slo's Avatar
I keep hearing what sounds like a leak coming from the drivers side near the headers everytime I step on the gas normal. I've checked for loose bolts on the headers and nothing. I know it's not a bad gasket as I just changed them with the Ford oem ones. Could this be the infamous loose plug? If so how can I check them, I ask this since I've never changed or checked plugs before. Could it be anything else? 1 last thing I also have a check engine light.
Old Feb 26, 2003 | 11:41 AM
soap's Avatar
Re: Need help to check plugs
With that light on, I would not drive your truck until you check your plugs........
--Joe
Old Feb 26, 2003 | 12:24 PM
LIGHTNINROD's Avatar
If you've never changed any plugs before, don't start with these. I had changed dozens of plugs on a few different engs. over time but it took me 4.5 hours to do my 01 L ones. It requires a few special(not really but the average tool box might be missing them?) tools and a lot of labor--the first time.
Drive it very cautiously to your dealer or the closest Ford dealer. Any of them should be able to check/change your plugs in less than an hour and they can identify the code. Good luck .
Dan
Old Feb 26, 2003 | 01:29 PM
captainoblivious's Avatar
Originally posted by LIGHTNINROD
If you've never changed any plugs before, don't start with these...
Don't listen to that.
If you can do this truck you can do anything.
Rule #1 - take your time.
As for tools, the only *special* tool you need is a 7mm swivel socket, it reallys helps for the coil pack bolts. Also an assortment of bandaids and or electrical tape/paper towels will be helpfull for the any cuts you will recieve
This is what I use:
For the coil packs 1/4 ratchet, 8" extension and 7mm swivel socket
For the plugs 3/8 ratchet, 6" locking extension, 3" locking extension(2), spark plug socket with rubber boot on the inside.
Thats it, I can do all the plugs in about 2 hours.
Old Feb 26, 2003 | 02:03 PM
SVT F15O's Avatar
Lightbulb
They are not hard to do. Just a little time consuming. If my brother and me team up on our trucks we can do a full change in about 30 minutes. He does one side I do the other. I always get stuck with the drivers side. HeHe. Not hard at all if you have a big tool assortment. Goodluck. -Mat-
Old Feb 26, 2003 | 02:09 PM
Don's Bolt's Avatar
he UB2SLO
Where r u from, maybee someone in your area can help you through it the first time, After that it is easy.
Old Feb 26, 2003 | 02:34 PM
Six Spd Z28's Avatar
Registered User
This is what I use:
Ditto I did mine in 2 hrs the first time
Old Feb 26, 2003 | 02:57 PM
Daves00L's Avatar
try this link:
http://home.midsouth.rr.com/lightnin...parkplugs.html
Old Feb 26, 2003 | 06:10 PM
ARTIE54's Avatar
Another thing that will really help you is if you know someone in a garage ask them to order you the Snap/On spark plug socket for Ford 5.4's. Its worth every penny it cost!! Good luck. Artie
