EGR Questions???
Old Feb 24, 2003 | 11:17 PM
MidsouthBolt's Avatar
Question EGR Questions???
Hey All,
Let me give you a little background on my problem. When I installed my new motor I put the wrong vacuum hose on the top of the EGR. It would not stay running. I had to keep my foot on the gas gas to keep it running. Found what I did wrong and fixed the routing.
Now my truck idles rough and you can smell that it is running extremely rich. I have changed all my plugs and coil packs. Sometimes when I first take off up the road (1/4) throttle the truck will stumble like it runs out of fuel...I can push the throttle to 3/4 and it will accelerate through the stumble and run fine.
I was wondering if the egr can go bad. Are there moving parts in the valve? Also I clean my IAC valve with some throttle body cleaner...when i fill it up it will leak out of the round cap on it.
Thanks for all your help!!!
Graeme
Old Feb 24, 2003 | 11:22 PM
cpeapea's Avatar
thats normal for the iac, as for the egr im not sure, you might have a problem with maybe the vacuum hose, maybe it kinked or its leaking?
