Which wire is the output voltage lead form our IAC ???
Old Feb 14, 2003 | 06:30 AM
Rob_02Lightning's Avatar
Which wire is the output voltage lead form our TPS ???
""""I MEANT TPS NOT IAC, SORRY""""
For the Nitrous Wiring, I must connect one white wire to the output voltage lead from the throttle position sensor.
Does anyone know which wire that is on the TPS plug ???
Old Feb 14, 2003 | 08:33 AM
LIGHTNINROD's Avatar
Rob: You're confusing me--is it the TPS or the IAC? I bet you mean TPS? Still d/k the wire answer.
Dan
Old Feb 14, 2003 | 06:55 PM
Sorry Lightnin Rod,
Yes I mean TPS,
I edited it,
THANKS
Maybe I can answer my own question
I adjusted my TPS 2 weeks ago
Would I be correct in saying since the red lead of the meter went to the Middle wire of the TPS, that must be the Output Voltage RIGHT ????
Sounds Right to me
Old Feb 14, 2003 | 07:11 PM
Probleminfected's Avatar
take a digital multimeter, set to dc volts
back plug (red)it into one of the hole, black to ground
open the throttle
if it changes voltage thats the output voltage
switch holes if not.
Old Feb 14, 2003 | 07:42 PM
well i decided to see what my babolt t/b's TBS was set at, since i read this.
it was at .958, so i fixed it to .982
thanks rob, i finally got off my butt after seeing that picture.
that should have been on my things to do to the truck list a long time ago.
Old Feb 14, 2003 | 07:47 PM
Flying Mofo's Avatar
Banned
i prefer mine set to .98
