Radar Detector problem in L...HELP (and its the L's fault)
Old Feb 12, 2003 | 10:16 PM
detail's Avatar
You guys are going to laugh at me but I swear this is true. Hell I should videotape it. I have an escort 8500 which i love to death. But since i have changed my plugs to the ngk-8's it does some crazy *****. Everytime I hit more than 8psi boost (as per my stock boost guage) it goes off full LASER until I let off the gas pedal. I got mad and exchanged the detector for another 8500. It worked fine for about 2 weeks and now it is doing the same thing. This one does it when I start my truck on occasion and when i nail the throttle. Sometimes it doesnt though.....I cant figure it out but its driving me insane. My brakes are going to wear out reeeeealy quick if this doesnt stop.
Old Feb 12, 2003 | 11:14 PM
Rayden's cloud's Avatar
When you go over 8lbs of boost, your probably going so fast the poor radar detector can't keep up with the 10 cops you are zipping past..
Old Feb 12, 2003 | 11:16 PM
ICULOKN's Avatar
Are those plugs non-resistor type or something?
Old Feb 12, 2003 | 11:56 PM
detail's Avatar
Dont know.....Paul at REM wanted me to try them instead of tr6's. This never happened before I changed my plugs to the #8's
Old Feb 13, 2003 | 11:11 AM
Fast Gator's Avatar
You might be onto something here
Old Feb 13, 2003 | 11:16 AM
brap's Avatar
I posted a question about this last week. Are your plugs BR8EF or BP8EF? Our trucks have to have resistor plugs, the coil packs need them if I remember correctly, Sal at PSP told me this. I had a tuner sell me the BP7EFS, come to find out they will do damage in the long wrong.
The BR series plugs are resistor plugs where the BP series plugs are not.
You might want to check on this.
Edit: Heres the thread, https://www.f150online.com/forums/sh...hreadid=106313
Old Feb 13, 2003 | 02:55 PM
wkuper11's Avatar
aren't those really cold plugs? what kind of boost/nitrous are you running with them?
Old Feb 13, 2003 | 08:50 PM
detail's Avatar
no nitrous....4lbs over stock boost. I couldnt keep a set of tr6's in my truck. They always looked terrible...stock looked better than those things. These plugs im running now are NGK R5724-8 stock #7317
Old Feb 13, 2003 | 08:53 PM
Flying Mofo's Avatar
Banned
Detail, be SURE those plugs youre using have RESISTORS in them!!
Old Feb 13, 2003 | 08:54 PM
detail's Avatar
I just looked them up. They are Non-Resistor.....Whats that mean and how bad is it????
Old Feb 13, 2003 | 08:58 PM
Banned
Whats the exact model # of those plugs.
Old Feb 13, 2003 | 09:02 PM
detail's Avatar
R5724-8
Look what I found...maybe solved the mystery..this is from NGK
Frequently Asked Questions
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
Old Feb 13, 2003 | 09:06 PM
Banned
Dee, those arent resistor plugs.
Not only does running non resistor plugs make weird **** like you had been observing, they will ultimately blow out your coil packs as well.
Old Feb 13, 2003 | 09:07 PM
detail's Avatar
Lovely......now I gotta change them again.....im soooo sick of changing the damn things.
Old Feb 13, 2003 | 09:09 PM
Banned
You should be ok with a set of NGK BR7EF's
