Plug change soon....antiseize or not?
Old Feb 12, 2003 | 07:47 PM
HEVYRESQ's Avatar
Antiseize or not with these aluminum heads?...Ive read both on this webpage...also, what should I torque these things down to to that they dont come flying through the hood?????
Old Feb 12, 2003 | 07:51 PM
cyntaxx's Avatar
I hear anti-seizing doesn't do much with our aluminum heads. The most secure way just short of getting the new 8-thread head is helicoiling. Check out my thread on it...
Old Feb 12, 2003 | 07:53 PM
SVT_KY's Avatar
No anti-seize ... I just use a squirt of WD40 to lube 'em up a tad ...
Makes 'em thread a bit easier methinks ...
Old Feb 12, 2003 | 07:57 PM
Rob_02Lightning's Avatar
I've used Anti seize Both times I've changed mine, now I have 9k on it and race it often and never had a problem.
To tell you the truth next time I think I'm gonna go against what everyone says and use a Mild Loc-Tite.
I mean why not, they say not to use Anti-Seize and I do with no problems.
Old Feb 12, 2003 | 08:02 PM
LIGHTNINROD's Avatar
I used Lubro-Moly(German), copper-based, anti-seize 15,000 miles ago and, as Denso says, finger-tight plus 1/16th of a turn more. No loosening problems so far.
Dan
soap's Avatar
Loc-tite won't matter with the amount of heat our heads make will it??
Makes 'em unthread a bit easier me thinks.
--Joe
Old Feb 12, 2003 | 08:03 PM
soap's Avatar
Same here Danno
--Joe
Old Feb 12, 2003 | 08:41 PM
Green_98's Avatar
how about on a 4.6? how tight should the plugs be? it seems that hand tight plus 1/16 is a bit loose
Old Feb 12, 2003 | 09:04 PM
lxtac's Avatar
Finger tight plus 1/16 of a turn put all my plugs right on 14lb/ft... which oddly enough is what ngk recommends as well as many other plug vendors for alu head plug torque.
I also used a copper-based anti-seize.
Johnie
Old Feb 12, 2003 | 09:13 PM
Flying Mofo's Avatar
Banned
JB Weld or Locite Triple Red
Old Feb 12, 2003 | 09:21 PM
lxtac's Avatar
LOL.... JB should hold 'em ndare
Old Feb 12, 2003 | 09:36 PM
captainoblivious's Avatar
Well that would make plug changes much more interesting
Old Feb 12, 2003 | 09:37 PM
Banned
True but keep the little bastard from launchin on ya, thats for sure
Old Feb 12, 2003 | 09:50 PM
SVT F15O's Avatar
I was told 35LB FT. I think what NGK says(17LB FT) is a little on the light side.
Old Feb 12, 2003 | 09:56 PM
On aluminum heads
in the words of Chris Tucker:
HELLLLLLL NO!!!!!
The object is snug the plugs in so they don't get loose and back out, not strip the 4 threads.
