Plug change soon....antiseize or not?
Old Feb 12, 2003 | 10:38 PM
Flying Mofo's Avatar
Banned
Originally posted by captainoblivious
On aluminum heads
in the words of Chris Tucker:
HELLLLLLL NO!!!!!
The object is snug the plugs in so they don't get loose and back out, not strip the 4 threads.
LMFAO
Old Feb 12, 2003 | 10:51 PM
NateTrun2's Avatar
where can you buy lubro molly. did a google.search and really didnt find anything. and 14lbs is the correct torque for these plugs? same for the stock ones?
Old Feb 12, 2003 | 11:02 PM
lxtac's Avatar
Originally posted by SVT F15O
I was told 35LB FT. I think what NGK says(17LB FT) is a little on the light side.
Not to be picky but to put out the correct info, I am looking at a NGK TR6 box right now.... it says: 14mm taper seat, Alu heads, 7-14 lb/ft OR Hand tight and 1/16 turn.
On their website they say 7.2~14.5 for our plug/head combo:
http://www.ngksparkplugs.com/techinf...s/techtips.asp
EDIT: also Denso's site says roughly the same:
http://www.densoiridium.com/installationguide.htm
Old Feb 13, 2003 | 09:06 AM
LIGHTNINROD's Avatar
Google came through for me:
http://216.239.39.100/search?q=cache...n&ie=UTF-8</a>
That's the GOOD stuff. I've used it for years on the plugs, wheel studs, back of wheels, exhaust bolts, etc.
Lubro Moly Anti-Seize
With the extended service interval of today's vehicles. The idea of breaking or damaging the spark plug threads in the cylinder head are every mechanics nightmare. Lubro-Moly anti seize is a product developed especially for vehicles with aluminum cylinder heads. This copper based lubricant resists high temperatures and places a barrier between the steel spark plug threads and the aluminum cylinder head. This barrier makes for easy removal. Also recommended for exhaust component assembly and oxygen sensors.
LM anti-seize 63371 $5.95
Dan
