throtle body problem
Old Feb 9, 2003 | 06:49 PM
LatemodelRacer2's Avatar
I ported my spare factory TB. I took the shaft out and cut it then i reinstalled it. I put it on today before i went to the track. I got to the end of my road and the truck was not shifting till like 3500 at normal driving. I turned around and went home and reinstalled the factory TB. I then went back on my way to the track. truck iwas fine then. i get to the track and it starts raining good thing it is only 10 minutes from the house. What could i have done wrong to the TB while I took the shaft out to port it? Truck runs like crap with it on but fine with stock one. is this the TPS voltage or a bad TPS in general.also the ported one did work before i ported it.
Old Feb 9, 2003 | 08:15 PM
LIGHTNINROD's Avatar
We need more info: Describe "cut it" in more detail. It shifted at 3,500 at every shift? Tell us more completely what you did to the th/body and exactly what happened as you drove it.
Dan
Old Feb 9, 2003 | 08:27 PM
i pulled out of my driveway applied normal throtle it then didnt shift until 3000-3500 and when it did it was harsh it did it to third then i tunred around and creeped home it doing it on the return trip to.
When porting:
I took the shaft out of the TB and cut one side of the shaft off. I cut where the butterflys goes in between the two pieces of the shaft. shaft is still in one piece.When i reinstalled it didnt want to go back together but it finally did. just ask if any more info is needed.
Old Feb 9, 2003 | 10:07 PM
Calightnin's Avatar
That sure sounds like a tps issue (which also does control some transmission functions). Set your voltage.
99L
03L
Old Feb 9, 2003 | 10:37 PM
i was going to take the tps off but i cant get the screws to loosen up.are they usaully this hard to unsrcew
Old Feb 10, 2003 | 03:02 AM
Ak.Silver2K's Avatar
TPS screws
No they aren't. They are tight but should break loose fairly easy. Important to set it right.
Mark
