nitrous+6lb how safe?
Old Feb 7, 2003 | 08:35 PM
btchnRod's Avatar
is anyone running a 100 shot nitrous with a 6lb pulley and a stock block? how safe is it if the program is a little on the rich side ??? tuner said it would be ok but i don't want to mess anything up down low.
Old Feb 7, 2003 | 08:38 PM
cpeapea's Avatar
unless youre running a built block its not safe at all
Old Feb 7, 2003 | 08:41 PM
cyntaxx's Avatar
anytime you run nitrous (especially something like a 100 shot) you want a flip chip with a nitrous program specifically burned for that application (more fuel, less timing, etc)...
you want a multi-program chip because chances are you wont be running nitrous ALL the time so you want a program that isn't so rich on the street w/o nitrous.
as for 6# and 100 shot, you've got more ***** than i do. there's another guy running a 75 (or maybe a 100 shot?)..skip i think, with a 5# and has had no problems with it. however, you're putting a lot of faith there on our rods...let's just say most think a 6# on a daily driver is as much as you want to add....
good luck.
Old Feb 7, 2003 | 08:52 PM
btchnRod's Avatar
i am runnig a dual program on the chip and both sides are rich. i think i read a few people that were running 100 shot with a stock block. just looking for more info before i have to go all out on the block.
Old Feb 7, 2003 | 09:00 PM
cyntaxx's Avatar
it *may* hold up it *may* not. anytime you're putting that much stress on the motor you're running a risk. With a 6# and 100 shot you're running a larger risk than someone with a 4#.
If you decide to go with it, MAKE SURE your programs are set up right, especially on the nitrous side.
If I were to go this route, I would have a couple of grand in my pocket ready to dive in a lot deeper (built motor, etc) before commiting my truck. Just my .02 though.
Good luck...one thing's for sure...she'll be quick!
Old Feb 7, 2003 | 09:44 PM
mecca's Avatar
That's basically committing suicide in my books! Don't do ittttt!
-Mike
Old Feb 7, 2003 | 09:52 PM
HANKFAN's Avatar
Anything more than a 50hp shot with a 6# lower will result in an expensive rebuild! However a 50hp shot and a 6# lower is an awesome combo!
Old Feb 7, 2003 | 10:01 PM
btchnRod's Avatar
my tuner told me it would be no problem. but again ihave sent my chip back three times to get re-burned. somehow they cant get my program correct. mph is still off and second gear is comming in late. rev-limmiter is hitting and their is no way i am going to try the nitrous side. looking for another tuner that has a little more experiance.
Old Feb 7, 2003 | 10:02 PM
cpeapea's Avatar
i would consult with sal, hes definitly the nitrous master
Old Feb 7, 2003 | 10:03 PM
Rob_02Lightning's Avatar
Dam that question sounds familar
Old Feb 7, 2003 | 10:17 PM
btchnRod's Avatar
is any one else have had or is having the same problem with the mph or rev-limmiter comming on? i changed to 4.10's and 2800 stall converter along with long tubes, sigle blade ,ported intake, 6 lb , hi-flows, vb kit, tr-6 and adjustable nitrous with sal's plate. oh did i forget the delta tunned by hmmmm??? better not say.
Old Feb 7, 2003 | 10:22 PM
My Limiter was moved to 5800 RPM
on all 6 programs I've ran so far.
it's perfect there
Old Feb 7, 2003 | 10:27 PM
btchnRod's Avatar
mine is set about the same but it just keeps comming on. any one have an idea why? tire spinn is to a minnimun running slicks and metco uppers. this truck hooks awsome!
Old Feb 7, 2003 | 10:40 PM
dirtchicken's Avatar
I already got a 2# upper. I am almost afraid to put my 6# lower on with rebuilding my bottom end.
easterisland's Avatar
10secL runs a 100shot and a 5lb lower. I think he runs a superchip by JDM...He's been doing it for nearly a year on his stock block 2000 Lightning.
