nitrous+6lb how safe?
Originally posted by easterisland
10secL runs a 100shot and a 5lb lower. I think he runs a superchip by JDM...He's been doing it for nearly a year on his stock block 2000 Lightning.
That is pretty impressive. I worry a lot with just my six pound lower. I have thought about throwing a wet 50 shot but I am chicken. I imagine with some care and really good tuning it probably would be ok. A person I trust says it could be done safely.
Does 10secL run a dry or wet shot?
Ive got over 100 1/4 passes with a 6lb and a 75dryshot.No problems yet.Ive got about 8000 miles on the truck.see sig for times.Im about to go 100 shot,well see what happens.Im just lookin for a reason to get into the 10s.Good luck on your quest.Any questions just ask.Most will tell ya to go with a wet shot which is safer but for about 500 you can get started with a 75 dry.Its all in the program.Pull lots of timing.Should be O.K."Should"J.L. sells nice blocks.Ihear they go 10s.lol
Originally posted by btchnRod
i am runnig a dual program on the chip and both sides are rich. i think i read a few people that were running 100 shot with a stock block. just looking for more info before i have to go all out on the block.
--wes
I run the EFI single nozzle NX kit.......Previously i had the NOS 05115 kit.......On the dry i sprayed 75 with a 3# lower. Since i switched to the NX i have upgraded to the 5#lower..... As easterisland said I have been running this combo for a year now on Stock bottom end. Its given me no problems so far. I always run the 100 shot and I use it alot! I have sprayed the 150shot a couple times as well. If it was me I would be careful of spraying and overboosting anything but a 99/00 Lightning. There are a few 01s running around with basically the same combo as me but its not gonna last forever! So we just have fun while we can! I know before long an engine is in my future......Hopefully it will hang on another season!
He has the NX Ford EFI kit. So it is wet. Everytime I see Hankfan's set up it reminds me exactly what 10secL is running. From the mounting location of the solenoids, bottle, and even the switches...
--Joe
Man you guy's wouldn't be hard on a guy would you??? I will never live that NOS dry kit install down but...... We all know who figured out he killer looking install on the NX kit. Seems like there are a few copy cats out there, especially with the fuel seloniod mounting location.
Can we throttle down the Juice for less power ???
I'm going with the Zex Wet Kit and I was wondering
if there's a way to cut it back to say 35 or 40 HP.
$500. and change for that HP Is a great deal and I would feel safer and would benefit greatly from the SUB ZERO WONDER JUICE COOLING THE T/B, Manifold, S/C + Intercooler
I found this
Select Size:
.032
.034
.035
.036
.038
.040
.043
.046
.052
.073
.078
.082
High quality precision machined jet, price is for single jet. These jets are compatible with nitrous and fuel. Select the size(s) you need and add them to your basket.
Does anyone know what comes with the standard ZEX #82021 "WET" Nitrous Kit-Complete 55-75 HP
I found this
Select Size:
.032
.034
.035
.036
.038
.040
.043
.046
.052
.073
.078
.082
