Pinion angle change with lowering?
Old Feb 7, 2003 | 09:33 AM
quiksilver's Avatar
I lowered the rear of my 02 L with Belltech 2" shackles. Just eyeballing it, it seems the geometry change would add some negative pinion angle to the stock setup. Anybody check this ?
Old Feb 7, 2003 | 03:24 PM
Twisted99's Avatar
you might pick up an angle finder..mine has a magnetic base..
check with the suspension loaded . -2 degrees is said to be best for launching.
Old Feb 7, 2003 | 04:23 PM
ICULOKN's Avatar
Re: Pinion angle change with lowering?
You may have got one more degree negative which does help some... It should be fine....
