TPS % question
Old Feb 4, 2003 | 09:54 AM
crockett59's Avatar
TPS % question
Hey guys,
I was wondering what % the TPS should be open @ WOT?
I tested mine last night with the Snap-on scanner and it read 91% @ WOT- 19.6% @ idle
Is that normal or should I try to adjust it?
Old Feb 4, 2003 | 11:46 AM
captainoblivious's Avatar
All TPS reports need a cover sheet!
If you want to check it without a scanner, pull the intake off and have someone press the gas pedal all the way down and look at the TB.
I had scanned mine a while ago but forgot what the TPS % was, I'd offer to re-scan and let you know tonight, but the weather isn't up for a WOT run.
Old Feb 4, 2003 | 12:03 PM
LIGHTNINROD's Avatar
To check for a correct TPS setting/adjustment, you do a voltage test.
Of course, you want the throttle plate(s) completely open at WOT, but the TPS probably will not be at 100%. If it were, it might/would end up putting a bind in the throttle shaft and could prevent the plate(s) from being able to go completely open.
Thanks Rob.
Dan
Old Feb 4, 2003 | 01:35 PM
SVTRobG's Avatar
Under 1.0 Volt is with the throttle blade closed.
At WOT the voltage will be creeping up on 5.0 volts.
