Is there water in my engine???
Old Feb 2, 2003 | 05:17 PM
Krix330cic(NJ)'s Avatar
Question Is there water in my engine???
Changed oil today, (5w-20 and filter) and when i removed breather cap, there was a light brownish/white sluge inside the tube, and at bottom of breather.. Felt like petrolem jelly, that kinda texture..
Oil looked fine though when it was draining... Maybe this coulda been from water mist when i washed my engine bay a few months ago?
Old Feb 2, 2003 | 05:32 PM
jgstang67's Avatar
condensation
Krix330cic,
I have had this issue since I have owned L.. I make alot of short runs with mine. (1.2 miles each way to work 7-days a week) and i feel this is a condensation issue in our motors. I also had the SAME thing on my 99 f-250 w/5.4 . I just wipe out the filler and breather now and then. Jon
Old Feb 2, 2003 | 05:35 PM
could be.. thats exactly what i do, short drives.. for now, im only about 2miles from work.
thanks
Old Feb 2, 2003 | 06:55 PM
Fast Gator's Avatar
thanks
Well If I where you, I'd buy a house Waaay down at the shore, so you will have a nice long commute everyday
Old Feb 2, 2003 | 06:58 PM
lol... is Manchester, NJ far enough? We close Thursday!
Old Feb 2, 2003 | 07:19 PM
Fast Gator's Avatar
Cool Baby
Drinks on the house
Old Feb 2, 2003 | 09:18 PM
69stangscj's Avatar
Registered User
Re: Is there water in my engine???
Sounds like you guy's don't drive your trucks far enough to burn all the moiser out of your motors. I wouldn't worry too much about it and just change your oil every 3000 miles or 3 months ....
Old Feb 2, 2003 | 09:28 PM
LIGHTNINROD's Avatar
I'd change over to a full-synthetic--for many reasons. Here are a few--scroll down to see the comments on "condensation inside your eng.":
http://216.239.57.100/search?q=cache...hl=en&ie=UTF-8
Dan
Old Feb 2, 2003 | 09:44 PM
i have been running a full synthetic, and change about ever 4,500-5,000 miles.. along with a fuel filter.
I think its fine, just wanted to be sure.. thanks guys!!
Old Feb 2, 2003 | 10:48 PM
tallimeca's Avatar
common
very common, noticed it two weeks ago on my father's truck when were were working on it, and i've seen it on mine in the past as well. I'm sure you'll see it more up here in the north/northeast region where it continiously heats up and cools down. Noticed it more once the breather cap is installed, so all that air is flowing back and forth. Change your oil regularly and you should be fine.
Old Feb 2, 2003 | 10:51 PM
Old Feb 3, 2003 | 08:59 AM
69stangscj's Avatar
Registered User
I still think you should change your oil every 3000 mile or 3 months. Synthetic is obviously better, but you still have dirt in your oil and that's what causes alot of the wear.
Old Feb 3, 2003 | 09:04 AM
mind as well then, to be on the safe side.. its cheap enough to change, and a lot cheaper then a new block!
Old Feb 3, 2003 | 10:16 AM
cpeapea's Avatar
yup, i wouldnt ever wait that long to change my oil synth or no, i bet when you drain synthetic after 5k or 6k that it would be black as heck
Old Feb 3, 2003 | 10:34 AM
rscoleman's Avatar
Oil is cheap insurance. Dirty oil will destroy the rod and main bearings, which isn't pretty.
