Is there water in my engine???
Old Feb 3, 2003 | 11:09 AM
Krix330cic(NJ)'s Avatar
so replace syntech at 3k too?? ill try doing that.. is the motorcraft or moblie 1 good enough? or should i be running like amsoil?
Old Feb 3, 2003 | 11:16 AM
Fast Gator's Avatar
So very true
Old Feb 3, 2003 | 12:49 PM
captainoblivious's Avatar
I've replacing the oil every 3k miles, and I run the Mobil 1 synthetic.
I would run the amsoil, but only 1 place carries it and they don't always have it in stock, so I decided to stick with the more popular Mobil 1 just in case I ever need a rush change (for some reason I don't like switch brands that much).
Old Feb 3, 2003 | 02:13 PM
damn, i just thought of something...
i switched to Mobil1 at i think 9,500.. went about 5thousand miles on it, and when i just did my oil change the other day, i put back in the motorcraft 5w-20 synt. blend. because i couldnt find any Mobil1.. am i gonna screw up someting??
Old Feb 3, 2003 | 03:49 PM
...i switched to Mobil1 at i think 9,500.. went about 5thousand miles on it, and when i just did my oil change the other day, i put back in the motorcraft 5w-20 synt. blend. because i couldnt find any Mobil1.. am i gonna screw up someting??
It shouldn't mess anything up.
If you feel uneasy about it though and want to change back to Mobil1 soon, get some engine flush cleaner stuff like Gunk and flush out the engine before you switch back over to Mobil1. It would be the perfect opportunity to do it.
ps. check your email
Old Feb 3, 2003 | 04:52 PM
LIGHTNINROD's Avatar
They will mix togeather with no problems. It just won't be 'pure' one or the other until the next oil change(or two).
Dan
Old Feb 3, 2003 | 04:55 PM
93Cobra's Avatar
it is due 100% to the fact you are making short trips with it. back in high school, my mustang would get this white stuff under the fill cap like you mentioned - lived two miles from school. after heading back and forth to college - 30 miles each way, this disappeared.
hope this helps.
Old Feb 3, 2003 | 08:33 PM
nothing there man.. ya sent to Chris01L@optonline.net?
Old Feb 3, 2003 | 09:11 PM
Fast Gator's Avatar
working days or nights now??? You go out for lunch? Whats the place right off Park Ave, red brick building?
Old Feb 3, 2003 | 09:17 PM
Workin' now... 3pm to 5am.. today and tomorrow..
We gotta stay here entire shift.. ya know, "watchin' stuff!"
You talking about the Pichnnio place across from the gas station?
There is also a Greek place / pub out the front gate, heading towards the white castle on rt.1..
Old Feb 3, 2003 | 10:02 PM
Fast Gator's Avatar
place Iam thinking about is when you leave the main gate go left on Park. First light under the overpass, turn right about a block up on the right.
If your working please keep ALL H2S releases north of wood ave, I'll be out walking tonight
Old Feb 4, 2003 | 11:16 AM
Well that could be a problem Sent it to your old account.
