Should I cut the bumpstops?
Old Feb 1, 2003 | 05:11 PM
quiksilver's Avatar
I installed the Belltech 2" lowering shackles, after driving a while to let it settle they lowered the rear (measured at the center of the top of the wheel well) by 1 1/4". Now, should I cut the bumpstops to gain back the loss in wheel travel, or will that let something else hit?
Old Feb 1, 2003 | 05:50 PM
speeder's Avatar
When I did my drop shackles I bought new shorter bump stops, But you can cut the stock bump stops if you have to.
Larry.
Old Feb 2, 2003 | 12:08 PM
captainoblivious's Avatar
I just cut mine for the drop. If you don't want to cut them, try and get 99'-00' bump stops for the rear, they are so much smaller then those yellow ones on the 01'+.
Old Feb 2, 2003 | 01:38 PM
mecca's Avatar
Cutting the bumpstops... that doesn't lower the truck more does it?
-Mike
Old Feb 2, 2003 | 05:01 PM
-Mike
Nope, just gives you a little more suspension travel.
Old Feb 3, 2003 | 08:46 AM
quiksilver's Avatar
Captain: So you cut or replaced yours, how much shorter are they than stock? And, just to make sure, with the shorter stops, nothing hits, right?
Old Feb 3, 2003 | 11:22 AM
quiksilver - I cut about 2 rings of those big yellow ones on my truck. Occasionally it still hits, but that is only on major bumps.
Old Feb 3, 2003 | 11:26 AM
RTKILLA's Avatar
the new ones from bell tech for the rear are even shorter then my 99 style ones. Plus they are a better material.
Old Feb 3, 2003 | 11:44 AM
HD4mula's Avatar
Do u have to cut those in Ls with just a 2" shackle?? I only need it for 4" drop in my HD.
Old Feb 3, 2003 | 12:34 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Cutting is fine as is replacing the bumpstops.
As for 'hitting', lowering changes the operating range of the shock so it isn't out of the question.
You should also look at addressing the sway bar end links also.
Cutting/welding is one option. Drilling a hole is another, or replace them altogether.
Bob
Old Feb 3, 2003 | 04:15 PM
Fast Gator's Avatar
Bob
Drilling new holes is probably the best option, because it lets you return to stock height in the future if you choose to. And best of all its free!
