Piston Size on Engine Rebuild
Old Jan 30, 2003 | 12:43 PM
Big1Daddy's Avatar
Piston Dome Size on Engine Rebuild
Hey all you fellow lower-end rebuilt engine owners,
My question is what dome size did you use on your pistons and what compression ratio did you achieve? I'm looking to use a bigger blower and significant N20, so I'm wondering what size
dome I should be using.
Any suggestions are much appreciated....
Douglas
Old Jan 30, 2003 | 12:49 PM
ib fast's Avatar
Re: Piston Size on Engine Rebuild
Douglas
My .20 over Manley pistons have 8.4-1 compression or 8.4.5-1 compression...can't remember which and i am too lazy to look
Old Jan 30, 2003 | 12:56 PM
Big1Daddy's Avatar
Yeah, that compression sounds right, but there are at least 0cc, -9cc, -10, -11, -11.5cc, -15cc -17cc, -19cc, -25cc, -28cc dome pistons out there. Just look at:
http://www.modularperformance.com/
under pistons and you'll see what I mean.
Old Jan 30, 2003 | 01:16 PM
ib fast's Avatar
The owner of Modular performance had a voice in my engine build as he had some dealings with my engine builder at the same time mine was being built.
Mine is built for high boost aftermarket blowers and not nitrous,so my dish size is probably n/a for your intended future use.
Sal,at PSP would probably have an answer for you on dish size.
Old Jan 30, 2003 | 01:33 PM
TimBurntire's Avatar
Um.......they are dished............not domed.
17mm dish w/pi heads is 8.90 to 1
Old Jan 30, 2003 | 01:41 PM
Big1Daddy's Avatar
..Dished... Good point, thanks Tim, I did put minus signs in front though!!!
Old Jan 30, 2003 | 02:49 PM
Big1Daddy's Avatar
I'm sweating it, as my builder says the 17cc DISH pistons I have will result in closer to 10:1, and Sal isn't available right now.
Old Jan 30, 2003 | 02:51 PM
ib fast's Avatar
So Tim, what ratio do my 11cc domed ...opps,i mean dished pistons come out to with pi heads?
Old Jan 30, 2003 | 03:19 PM
rscoleman's Avatar
Have you changed the deck height, milled the heads, and are you using stock head gaskets? How many cc is the head? There's more to compression than just the pistons. By the way what pistons did you buy? You need a ~39cc dish I believe. We need more info .
Old Jan 30, 2003 | 03:25 PM
ib fast's Avatar
[QUOTE]Originally posted by rscoleman
Have you changed the deck height, milled the heads, and are you using stock head gaskets? How many cc is the head? There's more to compression than just the pistons. By the way what pistons did you buy? You need a ~39cc dish I believe. We need more info . [/QUO
Old Jan 30, 2003 | 03:51 PM
LightningTuner's Avatar
With the 17cc dish, that CR on the 5.4 is 8.5:1. This same piston on the 4.6 nets 10:1. The reason it's lower on the 5.4 is because the piston is .120 in the hole. Hope this helps .
Old Jan 30, 2003 | 03:57 PM
Big1Daddy's Avatar
Makes my day Sal!!!!!
Old Jan 30, 2003 | 03:58 PM
Old Jan 30, 2003 | 03:59 PM
rscoleman's Avatar
I'll take Sal's word for it. Modular performance told me I needed a 39cc dish, which didn't sound accurate. Listen to Sal.
Old Jan 30, 2003 | 04:06 PM
Big1Daddy's Avatar
Use this:
http://www.modularperformance.com/compcalc.asp
Plug in 3.572 Bore
4.16 Stroke
44cc head
.040 Head Gasket
.120 Deck height
-17cc Dish
Result--8.83:to1.
Close enough for me......
Thanks Again Sal....
