WorksPower140 info
Old Jan 28, 2003 | 02:06 PM
TimBurntire's Avatar
WorksPower140 info
The WorksPower blowers will be showing up shortly, so I just wanted to give everyone some info.
Pricing on the Works112 is $3500.00
Pricing on the Works140 is $3850.00
Both units come with the rear entry plenum for greater capacity and are a straight bolt-on factory replacement unit.
There is no issue with plug changing. The units do not have to be removed for spark plugs to be changed. Because of the rear entry plenum, the one rear plug is a tight fit, but not to where you can't get to it, wether at the track or at a shop.
These units will push more air at lower boost than anyother superchargers available in the Lightning market today.
Don't forget, the 112 is a roots style, true 112ci blower and the 140 is a twin screw, true 140ci. This is due to the rear entry plenums that are included with the units.
Old Jan 28, 2003 | 03:35 PM
mecca's Avatar
Sweet.
-Mike
