Which is better?
Old Jan 27, 2003 | 09:26 PM
99Whtlghtnng's Avatar
Which is better?
which is better buying a higher octane at the pump or buying cheaper and buying an octane booster later? Is there a difference?
Old Jan 27, 2003 | 09:29 PM
Don's Bolt's Avatar
I would get the higher octaine at the pump. I am not a big fan of octaine boosters, they either discolor, or foul the plugs.
Old Jan 27, 2003 | 09:31 PM
VINNIE's Avatar
I'm with him.
Old Jan 27, 2003 | 09:32 PM
cpeapea's Avatar
octane boosters dont work, and if you want to boost octane use toulene or xylene
Old Jan 27, 2003 | 09:34 PM
SpankDog's Avatar
Banned
yea what they said, plus if you add the right stuff its going to cost you more then if you just get premium up front.
Old Jan 27, 2003 | 11:00 PM
Navi Man's Avatar
I would stay away from xylene as an octane booster as it's flash point and distillation range isn't hot enough. Toluene up to about 10% will work good as an octane booster and the percentage will depend on how heavily modded the engine is.
Old Jan 28, 2003 | 12:06 AM
Fast Gator's Avatar
Just spend the extra .10 at the pump and treat your baby right
Old Jan 28, 2003 | 12:10 AM
LatemodelRacer2's Avatar
I always have heard that premium gas is cleaner burning
Old Jan 28, 2003 | 12:19 AM
Suavy's Avatar
I use 94 Octane and I add a tube of Pensoil octane booster. The winters here in Michigan are pretty cold it was about 5 below last night. This conbo stops the detination and plane old spark knock.
Suavy
Old Jan 28, 2003 | 08:21 AM
LIGHTNINROD's Avatar
Re: Which is better?
Here is some 'backup' on boosters
http://198.65.157.241/forums/showthr...oosters+octane
Dan
Old Jan 28, 2003 | 01:04 PM
Fast Gator's Avatar
Re: Re: Which is better?
Dan
Its a good thing somebody around here knows how to use the search function
I like Mike T, answer on octane boosters...........
Its just as easy to remove the chip as it is to pour a bootle of booster in your truck. Excellent advice, just burn the bad tank of gas up and slide the chip back in
Fast Gator's Avatar
whoops
Old Jan 28, 2003 | 01:18 PM
VINNIE's Avatar
Re: Re: Re: Which is better?
Originally posted by Fast Gator
whoops
Yeah right.
Just padding that post count.HEHEHE
Old Jan 28, 2003 | 03:35 PM
Fast Gator's Avatar
Nope, just the dreaded double post!
Buts thanks for giving me an opening to make another post here
