Help: Passenger Side Headlight Doesn't Work!
Old Jan 27, 2003 | 02:41 PM
cobra97snake's Avatar
Angry Help: Passenger Side Headlight Doesn't Work!
ok, i installed the billet grille sunday, and after putting everything back together, later that night i noticed my passenger headlight was not working, so i checked to make sure it was plugged in, and it was, then i found out that the bulb was busted, so i changed both headlights today to the "blue" and the driver still works, but the passenger still doesn't work! what is up, it's plugged in and has a brand new light in it.......
Old Jan 27, 2003 | 02:52 PM
SVT F15O's Avatar
You didn't touch the bulbs did you>??? Maybe one of the prongs got bent>??? Try blowing in the plug maybe it got dirt in there>??? Check the wires for any breaks too. Do both the high and low beams not work>??? -Mat-
Old Jan 27, 2003 | 02:53 PM
let me check......
Old Jan 27, 2003 | 02:57 PM
Silver-Bolt's Avatar
How did you break a bulb while changing the grill?
Old Jan 27, 2003 | 02:58 PM
yeah, when i put the high beams on the passenger comes on.... so whats wrong when just turning them on?
Old Jan 27, 2003 | 02:59 PM
i dont know, i think either when taking out the headlight assembly either when putting them down on the ground or popping them back in, it might of broke??? i dont know.
Old Jan 27, 2003 | 03:01 PM
SVT F15O's Avatar
Sounds like a wire may have gotten pulled out of the connector or broken. Maybe a prong is bent(unplug the connector and look at the 3 prongs on the bulb. Maybe the low beam filament just burned out or you got a bad bulb. Try putting your stock bulb from the driver's side in there. -Mat-
Old Jan 27, 2003 | 05:48 PM
it was the new bulb i bought, i took it out of the headlight assem, and plugged it in, and it kept sorting out, so i took the stock one that worked and plugged it in, and it was fine, so i took the new one back, but they were all out of the "blue" so i just got a regular Xenon right now for $8 and the stock one, i still got one of the blue ones, so i'll end up buying the same brand and 1 more so i can get the blues to match.
thanks for the help!
