Lightning missing at steady cruising??
Old Jan 25, 2003 | 11:10 PM
Cobrakid's Avatar
hey guys,
I just put a factory tech valve body, and pan on, and filled trans
with MerconV.
Also did by pass valve (bypass) trick, and changed oil.
Now 2 days later, my truck is jumping while riding down
the road at a steady cruise.
The only other thoughts I have is, because of the crappy
winter gas mixes, and with my chip, I have run Shell 94
octane with non MMT octane booster (104 racing) to keep
it from pinging.
Could this have messed up a plug????
Johnny Lightning is installing Iridiums & supertuning with
Diablo chip in 2 weeks, should I worry about the "miss" or
just relax until the tune??????
Any ideas???
thanks,
Chuck in DE
Old Jan 25, 2003 | 11:13 PM
Rob_02Lightning's Avatar
YOU SHOULD WORRY ABOUT THE MISS
You have no choice, find it now.... Try pulling the coil wires one by one until you find the one THAT DOES NOT change the way it's running. Then figure out if it's a bad coil, or a melted plug
Old Jan 25, 2003 | 11:41 PM
Flying Mofo's Avatar
Banned
Sounds like you ate one of the electrodes off of a plug. Check it now man. You said you have to run octane booster to keep it from pinging.. Not a good sign considering they dont even work unless its Torco.
Old Jan 26, 2003 | 12:09 AM
DL's Avatar
DL
Check those plugs..
Old Jan 26, 2003 | 01:20 PM
LIGHTNINROD's Avatar
From my service manual(paraphrased to keep this 'short'):
Engine misses throughout driving speed range
1. Fuel filter clogged and/or impurities in the fuel system.
2. Faulty or incorrectly gapped plugs.
7. Weak or faulty ign. coils.
9. Vacuum leaks.
10. Dirty or clogged fuel injs.
11. Leaky EGR valve.
I left out what I thought was n/a.....but those are listed in their order of importance/possibilities.
Dan
Old Jan 26, 2003 | 01:26 PM
DL's Avatar
DL
Dan,
Your getting to fast, CC and I better watch out. We'll be left at the light crying..
Old Jan 26, 2003 | 02:39 PM
Originally posted by DL
Dan,
No way, Jose' I just wish I was as quick as you Augusta dooooods!
Dan
