Bolt on ground help
Old Jan 25, 2003 | 02:45 PM
Dman25's Avatar
Bolt on ground help
I found a bolt on the ground this morning under the truck, anyone else have this happen to them, my dad heard a thunking noise once while he was driving too. Please help thank you, its a pretty big bolt.
My dad now thinks its from the crankshaft pully, how many bolts should be holding that anyone know?
Old Jan 25, 2003 | 02:54 PM
SpankDog's Avatar
Banned
Unless you have a picture of it, thats not much help. But I guess you should get underneath and look around. Cant say that anyone else has had anything like this happen.....that I know of
Old Jan 25, 2003 | 03:02 PM
Dman25's Avatar
im under the truck as we speak, i keep checking here to see if some one can help me, umm how do i attach an image.
Old Jan 25, 2003 | 03:08 PM
Dman25's Avatar
its goldish in color, and says 9.8 on it
Old Jan 25, 2003 | 03:36 PM
Dman25's Avatar
Correction, make it two bolts now, i retraced where my dad drove and found another bolt just like it on the ground.
Old Jan 25, 2003 | 04:04 PM
L iminator's Avatar
Damn, I hope none of those Dodge Guys see this post. Good luck Dman; and let us know what you find. Sounds like a previous mechanic may have not tightened something up, possibly Trans. parts.
Old Jan 25, 2003 | 04:05 PM
J15BIG's Avatar
that is a pretty odd problem but could turn pretty serious if you dont do anything about it. If I were you and I still had my warranty I would bring it ino the dealership and have them check over everything.
Old Jan 25, 2003 | 04:10 PM
SpankDog's Avatar
Banned
not to mention its quite odd for a bolt to fall out in the driveway, while the truck isnt even moving.
Old Jan 25, 2003 | 04:12 PM
jwrape's Avatar
Motor mount bolt J/K
Old Jan 25, 2003 | 04:22 PM
Don's Bolt's Avatar
Check the cross member at the rear of the trans, I have a feeling it might be the trans rear bolts that fell off.
Old Jan 25, 2003 | 04:57 PM
Dman25's Avatar
ok i just checked those, they are in place, but , does the belt that run to the supercharger move a little for u, like can u turn it at all or is it very tight, cause i can turn it with my hand, and i think it might be something from that altough i have checked every bolt i could see.
Old Jan 25, 2003 | 05:33 PM
Dman25's Avatar
they did come off of the crank shaft pully, we are gonna put them on and then tell the dealer on monday. Thanks for all ure help everyone.
Here check this picture out so u can see it.
Old Jan 25, 2003 | 05:47 PM
Flying Mofo's Avatar
Banned
They came out of the crankshaft? Did you install a pulley by any chance? How many miles are on it and list your mods.
Old Jan 25, 2003 | 05:56 PM
Dman25's Avatar
My mods, lol, i have and air filter, and a Superchip, and its lowered which doesnt do anything, thats all my engine related mods, I have 24,000 miles on it. check out the link and see for ure self, if anyone else has a like a click click click noise while the engine is running, u can bet it is coming from here.
Old Jan 25, 2003 | 06:05 PM
NoSuprise's Avatar
All three of my supercharger pulley bolts came loose last month.
Lost two of then. The third one was out but rattling between the addapter and the pulley. I could turn the supercharger by hand! My truck is stock, 12k miles. The dealer replaced the whole assembly under warranty. Other people have reported this happening also.
