Grinding Calipers for 15x10 wheel
Old Jan 22, 2003 | 10:12 PM
FooFur's Avatar
How do you go about griding the calipers to fit a kick *** set of bogart 15x10 slicks. any pictures or tips would be great
james
2002 lighting
4 lower
2 upper
factory tech
rem intake
bassani catback
rem tuned chip
Old Jan 22, 2003 | 10:22 PM
LightningTuner's Avatar
You'll need to cut the dust shields down to about the rotor size. Then you'll need to grind about a 1/2" (no, that's not a typo) off the entire caliper outer face. You'll also need to grind the caliper mount arms, and you'll need to grind the brake pad retaining ears down as much as possible without making them break. Be very carefull when taking the caliper down, because you'll need to take a small amount off the piston seal to get the metal down that far, and you will also have about 1/8" of metal left between the piston and the outside of the caliper when done. After that, they will still hit the rims. You can try to take some metal off the inside of the rims too with a whiz wheel and rolock disc. After that they will still hit, but just barely. I strongly suggest NOT driving on the street with the brakes like this. Good luck.
Here is a pic of mine:
Old Jan 22, 2003 | 10:30 PM
FooFur's Avatar
thanks sal
hey, i have an order #809 when will it ship ?
thanks
james
Old Jan 22, 2003 | 10:33 PM
Should be going out Friday or Monday. In the future, don't ask for order status here, it's against the rules.
Old Jan 22, 2003 | 11:30 PM
cpeapea's Avatar
man jdm says it minor machining, but id say that thats a lot of caliper grinding! i think i will stick with 16's for slicks
Old Jan 23, 2003 | 12:48 AM
blown318's Avatar
How long did it take u to do the back SAL? Can you also give a how to on the front for sum bogarts?
Old Jan 23, 2003 | 12:57 AM
Mustangbadboy's Avatar
I have adapters that are custom made to run 15's with no cutting or gringing, have lug nuts too.
With these adapters you do not have to run the metric bolt patterns. You can run the pre-1997 bolt style.
If your interested in the its $125.00 per set including lugs!
Mush better and safer than grinding!
Mustangbadboy2002@yahoo.com
Old Jan 23, 2003 | 01:00 AM
blown318's Avatar
will the rims stick out at all??? Do you have any pics????
I might be intrested....
