Runs rough win first start!
Old Jan 18, 2003 | 11:29 AM
max1's Avatar
I have a 95 f150 5.0 4x4 with a remote start. Lately, when I first start it, it idles rough for a few secounds (this am it was about a min.) then it smoothes out as normal. I have no check engine lights on. Could it be the fuel filter or plugs? I also noticed a gas leak just started from the rear gas tank but that will have to wait until warmer weather. I am going to replace the fuel filter today anyway, any special tools needed? Thanks for any help.
Old Jan 18, 2003 | 12:26 PM
BMWBig6's Avatar
You may want to post this in one of the other F150 forums... unless I am in the wrong forum myself (this is the Lightning forum right guys?)... I hope you've replaced your fuel filter seevral times since 1995... if not, that's probably the problem. Good luck!
Old Jan 18, 2003 | 01:31 PM
LIGHTNINROD's Avatar
1. Vacuum leak(s)?
2. Leaking EGR valve or plugged PCV valve?
3. Dirty air filter?
4. Weak fuel pump?
Dan
