Factory Boost Question
Old Jan 12, 2003 | 03:12 PM
10_PSI_Guy's Avatar
Is the boost limited, or is 10psi the max boost the supercharger can run??
Old Jan 12, 2003 | 03:14 PM
Don's Bolt's Avatar
Stock yes
Put a chip and pulley and you can get up to 18 or so lbs of boost
This is what I run for boost.
Old Jan 12, 2003 | 03:17 PM
mecca's Avatar
Originally posted by Don's Bolt
Stock yes
18lb's on the Works is kinda different than our stock eaton... Don is a lucky man...
-Mike
Old Jan 12, 2003 | 03:19 PM
Don's Bolt's Avatar
On the stock blower, which has been on since september 4th
I still get 17psi
Old Jan 12, 2003 | 04:09 PM
Tim Skelton's Avatar
Re: Factory Boost Question
The boost is only limited by the pulley size. There is no blowoff valve like on a turbo.
Boost is just air backed up in the plenum with nowhere to go. Install hi-flow heads and exhaust and the boost will drop, while to airflow and HP will go up.
Looking at it another way, put a 1/2" exhaust on the L and the boost will go way up.
Old Jan 12, 2003 | 04:59 PM
mecca's Avatar
I still get 17psi
Now thats f'n sweet!
-Mike
Old Jan 12, 2003 | 05:06 PM
SpankDog's Avatar
Banned
Stock yes
Wow
Old Jan 12, 2003 | 05:30 PM
Fast Gator's Avatar
Stock yes
Show-off
