Full Review of JDM BILLET AXLE GIRDLE installation
Old Jan 13, 2003 | 09:52 AM
  #31
superfords's Avatar
I'm waiting on my QA1s from Ruslow before I start the lowering install.
you lost me on the non existance part.
later,
chris
Old Jan 13, 2003 | 10:22 AM
  #32
Fast Gator's Avatar
you know the noise you can never repeat in the shop
funny story, many years ago. I bought a brand new 1973 Gran Torino Sport, red w/black vinyl roof and the lazar strip down the side. 351 Cleveland 4V, very fast car
Anyway, the car had this frigging rattle, took it to the shop many times, couldn't find it. So finally I took the service manager out , driving over speed bumps in a shopping center at 45/55 mph in the parking lot. The car wouldn't make a bit of noise.
The "rattle" turned out to be the latch for the passenger seat back. When someone was sitting in the seat, it wouldn't rattle
Qa1's are my next spending project after I do the LT's
Did you purchase Ruslow's pan-hard bar also
it really tightens up the rear in corners
Old Jan 13, 2003 | 10:31 AM
  #33
superfords's Avatar
oh, yeah we get plenty of non existant noises. whenever you ride with the customer, they never act up. happens every time.
No I didn't buy the panhard bar. I'm going to try just the kit and shocks first and see how it works out.
later,
chris
P.S. Gran Torino with a stripe? Like Starsky and Hutch?
Fast Gator:
Old Jan 13, 2003 | 11:57 AM
  #34
The Swede's Avatar
TRUCK OF THE YEAR - 2010
Sweet !
Old Jan 13, 2003 | 12:32 PM
  #35
Fast Gator's Avatar
No it was a strip that changed color as it went front to back.
The strip was along the body above the wheelwells
But thats a 73
I had the maganum 500 wheels with Goodyears Polyglas (Now thats a blast from the past)
Old Jan 13, 2003 | 09:54 PM
  #36
Fast Gator's Avatar
vintage photography
Old Jan 13, 2003 | 09:55 PM
  #37
Fast Gator's Avatar
and
Old Jan 16, 2003 | 12:25 PM
  #38
Fast Gator's Avatar
Back to the top
in hopes that superfords see's what Iam talking about
Old Jan 16, 2003 | 12:44 PM
  #39
VINNIE's Avatar
Chris,
Just an FYI. If you get the panhard bar it will not work with the JDM Cover.
It does not look like the bracket will work.
VINNIE
Old Feb 9, 2003 | 12:50 AM
  #40
JeffsLightning's Avatar
Originally posted by superfords
next you need to refill your axle with gear oil. I pulled the fill hole on the front/driver side of the axle housing so I could monitor the fluid level. the instructions tell you to fill the axle here, but I have found it easier/cleaner to remove the abs sensor at the top of the housing and pour the fluid in from the top. this is totally up to you.
the truck took EXACTLY 3 quarts of the recommended SYNTHETIC 75-140 gear oil. I should note here that the instructions (and Ford) call for a bottle or two of Friction modifier be added to the axle. This additive is designed to make the clutches in the rear quieter by helping them to slip, your trac-lok will actually perform better without it. I left it out, but again check with JDM before straying from their instructions.
Actually my supplemental pamplet says to use 80W-90 syn. Not the thicker 140 stuff. Maybe it's wrong...who knows with Ford..
Old Feb 9, 2003 | 01:12 AM
  #41
SVT F15O's Avatar
I know right, like for example: I'd like to go in tomorrow and install my new lowering springs and sway bars, but I guarantee you a bunch of people will show up with windstars and exploders and tauruses (tauri?... tortises?) for me to work on instead.
later,
chris
So are you on the clock when you do this install>??? Damn that would be nice. Nice write up man. -Mat-
Old Feb 10, 2003 | 09:16 AM
  #42
superfords's Avatar
ford only uses two types of gear oil (that I know of).
80-90 is conventional gear oil.
75-140 is synthetic
later,
chris
Old Feb 10, 2003 | 11:07 AM
  #43
Chris what I was saying is that the Lightning supplement guide that I got with my truck says to use Motorcraft Premium 80w-90 rear axle lube. This same supplement says the rear axle is filled with a synthetic lube. Now the other regular F-150 guide(thick one) says to use Motorcraft 75w-140 in the 8.8,9.75 and 10.25 rearends. This to me applies to the non Lightning vehicles. Its most likely a screw up on Ford but that is how it is in the capacities and specifications guide. My 99 Lighnings guide was the same way... I know other companies make a syn. 80w-90 lube...
Old Feb 10, 2003 | 11:26 AM
  #44
Konig's Avatar
Need more posts like this one
Old Feb 11, 2003 | 12:30 PM
  #45
TZRLightning01's Avatar
ditto. Chris, what other mods are you currently running? did you get the chip, pulley and intake from Sal yet? inquiring minds want to know
