FYI - oil changes...
Old Jan 7, 2003 | 07:46 PM
sonichog's Avatar
Engine drain valve - apparently these work well...
http://www.fumotovalve.com/
Old Jan 8, 2003 | 10:36 AM
351stang's Avatar
Anyone have any experience with these?
I'm thinking about trying one. Any experience with them. If memory serves me correctly the drain plug is recessed. I guess you need an adapter.
Old Jan 8, 2003 | 10:53 AM
2Cool's Avatar
Have one, like it a lot. Makes an oil change a no tool job, as I hand tighten the filter with a film of oil on the gasket, so I can remove it with a good two-hand twist. Then just flip the little lever on the drain valve and its all good.
Very high quality brass valve, with a nice stainless ball**** seal. The valve is very heavy for its size, definitely feels like quality. No leaks at all so far. Install was a snap, just remove existing plug, then screw the valve in place with its new gasket. Its a one piece deal, as opposed to the Fram valve with its hose connector which I would promptly of lost before the next oil change.
Old Jan 8, 2003 | 11:04 AM
SpankDog's Avatar
Banned
I've got a Fram SureDrain and it works great.
Old Jan 8, 2003 | 12:04 PM
sonichog's Avatar
correct #
2cool -
I want to order one what is the correct # for our application is it #106...?
thanks,
SH
