What are the specs for the alignment of an 01 Lightning?
Old Jan 7, 2003 | 05:55 PM
brasil's Avatar
My F1's should arrive tomorrow, so I need to have them mounted balanced and aligned.
Old Jan 8, 2003 | 11:26 AM
brasil's Avatar
No replies? I feel rejected
Old Jan 8, 2003 | 12:47 PM
brasil's Avatar
Anyone? Sal? Jonny? Jim?
Old Jan 8, 2003 | 01:30 PM
builtfordfast's Avatar
Check here
My actual alignment specs
For Info , Click on Pic
My F150online Photo Gallery
Have a good day eh ! ......... Dave
Old Jan 8, 2003 | 01:36 PM
easterisland's Avatar
I would use the key words, alignment, specs, specifications, lightning, etc.
I followed the above procedure last year and came up with the following specs which I used and am extremely happy with.
Lightning Owner prefered:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Old Jan 8, 2003 | 02:58 PM
brasil's Avatar
If the Lightning owner preferred setting is used over the actual Lightning specifications will this cause the tires to wear prematurely or unevenly?
Old Jan 8, 2003 | 03:30 PM
I put 5K miles on my truck in the months I drove it last year. I had no uneven wear on my new nitto 555 295/45/18's.
I also had the Roush suspension kit on...
Old Jan 8, 2003 | 03:43 PM
The drop and alignment was done roughly 10,000 miles ago, have rotated the tires twice since and am very happy with the even wear and handling this setup provides.
When I went to the alignment shop, I gave them the Owner Preferred Specs as a guide and those actual numbers were what they came up with.
I would think that each truck, alignment machine, would very slightly with the numbers, so the Owner Preferred specs would be good numbers to try and achieve.
Old Jan 8, 2003 | 06:09 PM
brasil's Avatar
what would you recommend for a truck with the stock suspension?
Old Jan 8, 2003 | 10:41 PM
Spike Engineering's Avatar
Stock alignment specifications.
