Question about installing delta chip(not totally switch placement related)
Originally posted by LIGHTNINROD
and keep the ign. key away from the ign. sw. before you disconnect the harness. Turn the h/l sw. 'off' before you reconnect the battery cable after hooking the PCM back up.
Good luck!
Dan
Good luck!
Dan
So why do you keep the ign. key away from the ign. sw.?????
Will the key not work if you do have it near the ign. switch when your done?
The above quote is from Sal back in June of 2001. There may be other reasons too? Just giving a 'heads-up'--keep your key away from the ign. sw.(I drop mine in the cupholder on the console) when 'messin' with the PCM or when disconnecting the battery.
Dan
That's where I want my switch, but it's going to have to wait until it gets warmer, above 30 degrees for the high. Other than that though the chip is in and the truck seems to love it
Thanx for all the help,
Bill
.Thanx for all the help,
Bill
