Ugent, Wheel Stuck
Old Jan 3, 2003 | 02:53 PM
VINNIE's Avatar
Originally posted by Hilander
Thanks again, It came off with no damge, weird, anyway as the bolt has turned in the hub I am going to replace it. (The bolt that is)
Dealer has no 14 mm bolts for the 2000L, So having one sent for tomorrow...geeez.
My question is, Should i just unbolt the rear brakes remove the disc. Then when replacing the bolt do i install it by hitting it on with a hammer? Should i heat it first? Any advice again would be appreciated.
Since I have broke 2 studs so far I can tell you the only right way to change the stud is to take the axle out.It $ucks but there is no real alternative. At least you get a chance to change your rear lube.Which BTW is also expensive.
Sorry to be the bearer of bad news.
If there is another way I do not know it.
VINNIE
