lowering kit
Old Dec 28, 2002 | 04:44 AM
buckeye's Avatar
lowering kit
santa got me a lowering kit for my 01 and it is a ground force does anyone have one of these kits one there truck? and how do you like it. hows the ride.
Old Dec 28, 2002 | 01:41 PM
cobra97snake's Avatar
that, belltech, eibach, and western chassis, are the most popular, there are alot of people on here with that kit, and alot of them like it, you really cant go wrong with what brand lowering kit you get, everyone that has a different brand loves there's so you'll like it. they all basically accomplish the same thing.
Old Dec 28, 2002 | 01:55 PM
VINNIE's Avatar
Here is a pic of mine with a Ground Force(FRPP) 1/2 drop next to a stock height L.
Old Dec 28, 2002 | 07:29 PM
redlightspecial's Avatar
I have the FRPP kit, which is the same as your Ground Force kit. I like the way the truck looks. It's not as radical as some of the kits out there, which was what I was looking for, as I still need to tow and haul from time to time.
I find the ride to be slightly stiffer (I assume because the rear shocks are partially loaded at all times). I've also noticed that the steering is more sensitive as well and the handling feels more taut
I would recommend using the NAPA cam bolt kit on the front. Some owners also install Herb's washers at this time to prevent the dreaded clunk from the steering. In my case, I opted to have the steering stops greased instead, and have not heard the clunk in over a year.
An alignment is a must after the install.
Old Dec 28, 2002 | 08:11 PM
BlkBanshee's Avatar
Suspended Pending Email Reply
Vinnie, are you still running stock shocks, or did you upgrade? I love the stance your truck has. I was going to go with a 3/4, but you may have just changed my mind!
Old Dec 28, 2002 | 10:26 PM
VINNIE's Avatar
Still running stock shocks(front and rear) and the truck had a 1.59 60 ft.
Remember that I also have 20s and they are about 3/4 of an inch taller (295/40) then stock tire height.
That does help fill the fendewell a little.
VINNIE
Old Dec 29, 2002 | 01:06 AM
Hilander's Avatar
Just installed the Groundforce aka FRPP kit. Nice kit, not too low but low enough to have to watch the parking kerbs and some entrances.
If you value the front of the truck I would not go any lower than the 1" drop in front.
Old Dec 29, 2002 | 08:10 PM
buckeye's Avatar
thanks for all the feed back.now i cant wait till i put it on
Old Dec 29, 2002 | 10:42 PM
Rob_02Lightning's Avatar
Every post I look at, I see another picture of V's Lightning.
I always said if I had 18"'s, I would just leave it out all day
to show it off
Old Dec 29, 2002 | 11:21 PM
VINNIE's Avatar
to show it off
Is this better
Old Dec 30, 2002 | 06:27 AM
Ya but your looks sooooooooooooooo much better.
I think I'll have to start the first installment payment soon.
Old Dec 30, 2002 | 09:12 AM
trashguy's Avatar
vinnie
did u change the endlinks with the 1 inch springs?
Old Dec 30, 2002 | 09:39 AM
SVT_KY's Avatar
Vinnie,
I had heard that if you lower and keep the stock
shocks you will wear them out a lot quicker. Any
indication of that so far? The ROUSH shocks are
Bilsteins, but are setup differently to compensate
for the drop. The only thing I have left is to replace
the Beehive bumper stops with something better.
I like the rollpan look, but dont' want to give up
towing..... Any solution?
Cliff
Old Dec 30, 2002 | 10:18 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
true statement. My front Bilsteins were SHOT well before they were replaced with QA1's at 20K miles. The rears didnt seem that bad.
However, I've had a 2/2 drop for seven months/one year respectively.
Bob
Old Dec 30, 2002 | 05:30 PM
VINNIE's Avatar
Originally posted by SVT_KY
Vinnie,
Cliff
Cliff,
I have not noticed any real difference yet, but you are probaly right.
My biggest difference is the anti-sway bar.When that thing is off OH MY GOD the L dances around the street.It is almost scary.
About the rollpan. You can do what I am going to do .Get a hidden hitch. It goes behind the rollpan and the licence plate lifts up(Hinge) and there is a hitch there(obviously there is a hole in the Rollpan behind the lisence plate).It works just the same as any other hitch and you will never know it is there. A bonus is even more protection behind the rollpan.
VINNIE
