Started to Strip Wheels to be Polished
Old Dec 18, 2002 | 11:30 AM
Konig's Avatar
those are going to be bad *** man.... im suprised I havent seen someone do this yet
Old Dec 18, 2002 | 12:31 PM
Navi Man's Avatar
Those wheels are looking pretty good already TampaBlack99. Are you going to polish the whole wheel or paint some of it? It would look pretty good with the spokes painted black and the rest polished, or maybe just painting the outside of the spoke and everything else polished. Good luck on your project, but it's looking pretty good so far.
Old Dec 18, 2002 | 01:06 PM
TampaBlack99's Avatar
The WHOLE wheel is going to be polished.
No clearcoat. We have another set we are going
to do a combination of polishing and powdercoating.
We will polish the outside and have the inside of the rims
powdercoated to the color of the truck they will go on.
Does anybody now if the brake housing can be polished
and what it is made of. Thanks
The Swede I think has polished 99 rims.
Old Dec 20, 2002 | 07:26 AM
madramper's Avatar
What are you using to polish the wheels? I have been trying to get info on this since I bought my truck. Tools? Polish? etc
Old Dec 20, 2002 | 09:12 AM
air1kdf's Avatar
Strip first. Aluminum stripper is different then regular paint stripper. Some strippers will have a nasty chemical reaction with aluminum.
Start sanding with about 400 grit wet dry, then work you way up to 1000-1500 grit, then use any aluminum polish like mothers. Then clear coat to protect the finish, because it will oxidize if you don't.
Old Dec 20, 2002 | 09:47 AM
1) any stripper will work (mine was $18 from Lowes)
2) Air grinder used to knock down large flat areas and inside of wheels
3) Eastwood Greaseless compounds on Buffs (80, 120, 220, 320)
4) Wet sand flat areas smooth
5) Tripoli on small 3" Buffs
6) White Rough on Buffs for final brightness
Optional clearcoating, But I would not as most tends to yellow.
Good Day!
Old Dec 20, 2002 | 10:10 AM
NCETRY's Avatar
I have thought about doing this to my 01 wheels for a while now but what are you going to do about the center caps. You can't polish them and crome ones might not match. Maybe BAbolt might make some It should look great.
Old Dec 20, 2002 | 10:50 AM
One thing at a time. Will probably just get chrome center caps. Or make new ones.
Old Jan 19, 2003 | 01:00 AM
SCOTTSBEATER's Avatar
Any updates yet? last we saw you had the inner part of the wheel polished. Anxious to see the whole thing.
Old Jan 19, 2003 | 11:53 PM
'00BlackLightning's Avatar
Originally posted by J.D. Blackwell
I have been scuffing my 20" reps down to be repainted. All I been using is some 320 grit. That's all, but I am repainting them, not polishing them. If someone wants to repaint there wheels, just scuff them down a little for the paint to stick. It has been taking me about an 1 1/2 hours per 20" wheel.
J.D.
What silver paint are you using on the wheels? I was thinking of trying a re-paint on a spare wheel I have. Thanks.
